I've been doing a LOT of reading trying to decide what to buy for my first projector... upgrading from a 61" CRT-RPTV.... I use an HTPC, DVHS and cable-STB.
I originally was leaning to the Optoma HD-70, but then found the HD1000u at essentially the same price. But my room is a problem. It's the living room area of a 25'x 40' great-room. My sofa is essentially 23-34' from the "viewing wall" where the RPTV currently is located. Walls are white knock-down and ceiling is white popcorn. 15' sliders (with verticle blinds) on the North wall to my left. I really didn't want a projector in the center of the ceiling, so I started looking at the Pany AX-100 for it's long throw and lens shift (not to mention glowing PQ reviews). But reading that with minimal zoom at 23-24' the light falls off about 63%, I guess a center-ceiling projector is my only option, since a lot of viewing will be with some ambient light due to this room.
So, I was back to the HD1000u.... then I read THIS review at Home-Theater-Review which indicated that the greens, such as football field grass looked like peasoup! ????
And they showed a CIE chart with the green point substantially off the target and further said the pj had no means of correction for this green error. The PJ was supposedly calibrated by ISF Calibrator Steve Martin, who made the claims about the green error. Has anybody else seen/reported this color-decoder error? What to believe. Ifit is true, that the green is that bad, it sounds like a deal breaker!!!
The color may be slightly off - I don't know. I haven't noticed a problem. I was watching the bowl game on ESPN2 HD last night and everything look perfectly fine to me.
