Originally Posted by jonLavs
To me the Verus Grand bookshelf is in between the 5B & 6B with an upgraded tweeter and better sensitivity. I'm sure it sounds great and all, but I would think that the 5T would be a fuller sounding speaker with two 5.25" woofers versus just one 5" woofer in the bookshelf.
Originally Posted by BESLC
Izeteci/Jonlavs
I am in the process of doing an upgrade to the Verus towers and center for the front stage, I currently have 4-5T's and a 5C.
My thoughts were to replace the 2-5T fronts and the 5C, keeping as Jon indicated the other two 5T's for the surrounds. I am not sure I understand your reasoning Izeteci, on going to a bookshelf over the 5T? I would think as Jon indicated the 5T would be a better speaker between the two.
I am interested in your thoughts, thank you for your time.
Izeteci/Jonlavs
Well to start I only use the 5Ts for surround so a nice tower is a little overkill.
I used to have the 5DBs but I didn't feel like mounting them on the wall again in my new apartment so I switched to the 5Ts. They sound great but I have them on concrete blocks just to get them up to ear height and I really need them higher but I don't want to add more blocks. Right now if you sit in one of the seats far right or far left your head is almost right next two the speaker and it can be a little much. In the centered listening position it sounds great.
So that's a little back ground. Also it's not a big deal but my wife did bring up the point that my black 5Ts don't match my new cherry VG speakers.
Any ways,
I would say the VGB is more between the 6B and 5T. I don't think the 5B is even close in stats and sound.
5B = (+/- 3dB) 75 - 20,000Hz
6B = (+/- 3dB) 48 - 20,000 Hz
5T = (+/- 3dB) 55 - 20,000 Hz
VGB = (+/- 3dB) 59-20,000 Hz
The VGB also has a phase plug for smoother mids, better power handling and less distortion. Also the new tweeter is crossed over lower than the old tweeter to take off a little bit of the upper mids from the woofer.
I would say the 6B or 5T has a bit more bass extension but that's about it.
After listening to the new bookshelf speakers it really got me thinking about replacing my 5Ts.
I bet the VGB with the 8D or 10D for a 2ch set up would sound great.
I hope this helps explain my thinking a little better.
I really wished they redid the 4BP with two new tweeters and the 4" woofer with a phase plug. I bet you it would sound amazing!!!! Oh well
Because of this, I have decided that it is time for an upgrade.
Modern mastering jobs seem to ruin otherwise decent recordings IMO.
