Originally Posted by kb71
Hello,
After reading numerous reviews and posts, I have decided to go with the Aperions for my dedicated HT. I have a 16X20 room. On one side, where the surround speakers need to go, the wall is a half wall. I could mount a speaker where the ceiling (8ft ceiling) meets the wall, as there is 12 inches of "wall" before it opens up. I was thinking of going with the 534-SS. Would this speaker work mounted this high up and maybe aimed toward the seating area? Can I mount from the ceiling? I'm assuming if I put that side near the ceiling, I should mount the other side the same.
Then I was going to use the satellite 422s hanging from the ceiling as the rears. (7.1).
Fronts and center are 633-T, 634VAC, and s-10 sub
How does this sound?..no pun intended :-)
Hello,
I hace the 422's mounted on the ceiling with adjustable mounts. They seem to work fine.
). Remember the 50-100 hour breakin period before you do any critical listening tests. You're gonna love these
so another $500 smacks puts me over my budget. hey, we gotta draw the line some where.
