Originally Posted by Hicks
There is a little bump in the frequency response around 200 Hz and Audyssey sees the down slope of that bump and thinks the speaker is going to continue to roll off from there, but it doesn't, it flattens out down to about 70 Hz or so.
Personally if it were me I would set the crossover at 80 and 200 and listen to it with both settings and see which you prefer.
I did some more reading in the Audyssey thread, and accidentally stumbled upon a post from someone whose crossovers on his mains (not Aperions) were being set higher than his specs indicated they should. He did some measurements (wish I understood more about them) and discovered that his listening position was in a null for one of his fronts. I wondered if this might also be my problem, so I moved my center as far back on my stand as possible. Lo and behold, Audyssey recommended a crossover of 120hz rather than 200hz.
I tested it at several other spots on the stand and always got 150-200hz from Audyssey. I wish I were able to push it a bit farther back or pull it out closer from where I originally had it, as I think I'd get a lower recommendation than 120hz from Audyssey if my space allowed me to do either. I'm convinced that my listening position is in a null for my room if the 5C is placed near the front of my stand. That may also explain the different readings Audyssey gave me on my 5T's after I moved them slightly. Interestingly enough, the polarity warning Audyssey repeatedly gave me for the 5C earlier was not given once after I began moving it around on the stand. Perhaps that was related to the null placement as well???
Anyhow, thanks for your feedback. I'll probably listen with the 5C crossed over at 120hz for a few days, then switch it to 80hz to see which I prefer. I just knew it shouldn't need to be crossed at 200hz, given the specs. Perhaps my experience will help someone else who runs into this issue.
I can see what you are saying about a difficult room to work with though.
