AVS › AVS Forum › Audio › Speakers › *** The Official APERION Thread ***
*** The Official APERION Thread *** - Page 196
post #5851 of 6860
You have more than a foot...I'm sure you don't use that full screen...
You definitely want to get those speakers away from the walls and the VGC off the floor!!!
post #5852 of 6860
Yes, of course I use the full screen. I was also told by the manufacturer (DaLite) that the tensioning system works best when the screen is fully unrolled...and they strongly suggest not re-configuring it by too much.
As far as the side speakers go...certainly no where for the left speaker to go...there's a wall, and the screen. Done. They are more than 16" or so off the back wall (notice the subwoofer is behind the screen, and the front of the VGTs are actually slightly ahead of the screen)
post #5853 of 6860
You may consider building a small riser for your VGC and then carpeting it with the same carpet. That, plus the feet things that come with the speaker should allow you to angle it nicely towards the listener. Then, you can make it the exact size you need vs trying to find a stand. Many center stands come in different sizes, though, so that may still be an option.
EDIT...here's an example of what I mean from another forum member:
post #5854 of 6860
Originally Posted by Roger That View Post
You may consider building a small riser for your VGC...
Yep, did that this morning. Re-purposed a pair of bookshelf stands...Cut them way down to the precise size that I needed, and reassembled. I'll post a pic ASAP...but the center sounds quite a bit better...time to run YPAO again. :-)
-Kevin
post #5855 of 6860
Nice set-up. What speakers are these? And the sub? Wow, that's huge!
post #5856 of 6860
No idea. Not mine. Found it while perusing the "What's Your System Configuration" section.
post #5857 of 6860
Sub looks to be SVS PB13Ultra in cherry finish. Speakers initially looks like Verus Grand towers and centre, but I'm not certain on that
post #5858 of 6860
Acutally I am wrong on the speakers--just looked again. . .I should be shamed--I have the VGTs and the SVS subwoofer
post #5859 of 6860
-Kevin
Okay, here are the pics of the new center speaker stand:
The nice part about making my own stand is that I was able to make it *exactly* the right height. Works well.
-Kevin
post #5860 of 6860
I've been looking for a pair of cherry 5DB surrounds. Never see them. If anyone is looking to sell theirs please pm me.
post #5861 of 6860
-Kevin
Nice work!
post #5862 of 6860
I have the VGT, VGC, VS, and HSU VTF-15H...
The setup is AWESOME for home theater!!!!! Can't get any better!!! My issue I have is hunting down all the rattles and squeaks coming from the house... But the sound quality is amazing!! You can't get a better sub unless you want to spend twice the money with an entry level JL Fathom or 12 times as much with a JL Gotham.
I highly recommend the Verus Grands and the HSU VTF!!!
Excellent, glad to hear you are enjoying the set up!
Those like Dali Helicons to me and of course the SVS PB13-Ultra. I had the pleasure of hearing two Ultras in a system before, it was indeed insane!
-Kevin
Awesome, good team work everyone on helping Kevin out!
post #5863 of 6860
I wish I could help but we haven't had any even in open box for quite some time.
post #5864 of 6860
Hicks let me know if you see any. I was thinking maybe someone would trade them in for verus ones or something?
I would then use my 4bp's for rears in a 7.1. What do you think about that? Or would i be better off keeping the bp's as sides and get some 4b's for rears?
post #5865 of 6860
I will but there is very little chance I will ever see them again, the last pair sold just happened to be one year ago yesterday so the one year trade up window on these is officially closed.
Also the Verus Surrounds are actually $90 less than the 5DBs were (Aperion looking out for the little guy again! ) so techincally they wouldn't even qualify for a trade up to the VSS.
post #5866 of 6860
Hicks, any chance of having a sub promo on the 10 or 12d similar to the 8d? Or is there a discount on the 10 or 12 inch subs for buying 2?
Gene
post #5867 of 6860
Gene
Probably not on the 12s since we are so far out of stock, but if you give me a call we could probably work out something for a 10D package.
post #5868 of 6860
Gene
post #5869 of 6860
I am very interested in the Verus Forte Tower speaker system. I live south of Boston and would like to demo these speakers. I was wondering if there are any members in the area so I could take a listen.
post #5870 of 6860
Hi, I am new to this Forum and decided to join to see if any Aperion speaker owner's can help.
I purchased a 7.1 speaker package from Aperion Audio during 07/09, which includes a Bravus 12D - Dual Driver Powered Subwoofer.
Until recently the speakers have performed admirably.
However, now the 12D subwoofer exhibits a background low noise rumble even when all of my HT gear (receiver, etc.) is powered off.
From what I have read at the Aperion forum's this is a known problem w/the 12D, which may be related to the sub's amp.
What I'd like to know is if anyone else has experienced a similar problem with their Aperion sub, what the resolution was, can this speaker be repaired and is it still covered under warranty?
Unfortunately, I ordered my speakers w/the cherry finish and Aperion does not seem to offer this option anymore.
Any help/feedback is appreciated, thanks in advance.
post #5871 of 6860
Have you contacted Aperion?
post #5872 of 6860
Not yet, but I will this Monday.
post #5873 of 6860
Hi and welcome to the forum.
Definitely contact Aperion, but it also sounds like it could possibly be ground loops too. Not sure if anything changed about the time the hum/rumble started, but the normal suspects would be junk coming in your cable TV line, dimmer controls, or a bad ground connection outside. To troubleshoot, you can try to disconnect cable TV at wall, check; disconnect all inputs to sub, check; then try a ground buster adapter at plug (removes ground from sub's power cord line). Note: The cheater plug should really not be the long term fix, it would only be masking a bigger problem. Good luck.
post #5874 of 6860
Since my HT setup has not changed during the past two years, I doubt the noise is related to a ground loop issue.
If I power off/on the sub or change its settings to mute/auto the noise stops, but as soon as the sub receives a signal the background noise/rumble starts up again.
If I change the subs setting to on the rumble noise also starts.
From what I have read at the Aperion Audio Forum's it appears there may be an issue with the 12D's amp. This problem has been reported by other individuals who own a 12D sub.
post #5875 of 6860
Guys I currently have a onkyo 805 Ultra 2 reciever and the JBL venue series speakers......I'm In the process of planning a custom theater room, and I'm thinking of upgrading to the marantz 7005 and the aperion grand tower package and maybe the pb ultra 13...........my question is........is it worth the 5K+ for all of the that and will I hear a huge upgrade in sound?
post #5876 of 6860
Hard to say, but at least in the case of the Aperion's, it's free to find out.
I have the grand towers paired with the svs pc ultra 13. I can recommend the pairing. ;-)
post #5877 of 6860
I would try the speaker upgrade first, without doing the AVR upgrade. As a fellow owner of an Onkyo 805, you should have plenty of power to sufficiently evaluate the speaker upgrade.
If you want to then audition the AVR upgrade, then so be it. When you make a bunch of upgrades at the same time, it is impossible to determine what particular piece of the upgrade is "what did it".
post #5878 of 6860
Hello,
Does anyone has or could take a picture of their verus grand towers with the spikes on? or with the spikes with the rubber foot? Are you using another solution instead?
I havent found any pics with them.
post #5879 of 6860
Don't know exactly what your asking but I have spikes on my towers and I just put a quarter under the spike so as not to damage the carpet.
post #5880 of 6860
Oh, I seem to remember that they also have some rubber foot of something that you use with the spikes to protect hard floors and stuff....can you post pictures of your towers?
I'd like to see how they look with the spikes on....do they add more stability to them? By the time I plan to buy mine my baby is gonna be a toddler and I'm a little worried...
I was considering the outriggers from soundocity.com. Tom Norton from Home Theater Mag used them and recommended them over the stock ones... I'm looking for user opinions...Plus it'd be fun to see some more pics of the Grand towers!
  Back to Forum: Speakers
