Decided to audition the Verus Center I have not listened to another speaker since 2003. Purchased the 7.1 Klipsch
RF3 II system back then. Three years ago we moved and it included a larger room I could dedicate to the theater. In the larger
room it always seem to lack detail especially in the realm of voices. It arrived yesterday and I'm now working on determining if
this is a worth while upgrade over the existing system. I finally upgraded my Avr-4806 to the 4520ci back on the 7th, really
surprised on the improvement in on rear sides and back speakers. I though the best way was to get used to the Verus Center
was to have in for 3 weeks then switch back the my rf3 center. For curiosity I installed the Verus without calibration and tried several
movies. The Verus required about 15 clicks upward on the volume to hit the normal levels. This put the Klipsch towers overrunning
the center. Next I ran the Audyssey all points, showed the center was small, set to 80hz. It set the Klipsch towers to -5db which helped
greatly as you can hear the sensitivity differences easily between the towers and the center during the tone calibration. The literature
that comes with the center shows a 50hz response, I changed in to 60hz manually. It will definitely take some time to determine
as it is not really apparent yet, I have not watched last night due the flu. Any helpful suggestions properly auditioning the Verus
would be great, I do not have any positions issues and the voice right is set to on stand. I will keep updating as I move along, I took
a week off due not being able to shake the flu so I have plenty of time to listen to some of the movies I like and gave the Klipsch trouble
on dialog.
