I need to order a 20' component video cable. After some research it's apparent that there is definitely a difference between poor quality cables and good qaulity cables. I've found that both monoprice and bluejeans cable are usually comparitively priced and sell good quality cables. In this instance however there is a huge price difference between them on component cables (bluejeans $95, monoprice $23).
Now bluejeans cables list the specs of the cable construction very well and using the article http://www.audioholics.com/techtips/...ideoCables.php as a guide I know exactly what I'm getting.
Monoprices specs I'm unsure of. In this instance I'm not sure if the cables are comparable or if the one from monoprice is of lesser quality.
Blue Jeans
http://www.bluejeanscable.com/pages/...s/7710tech.htm
Monoprice
http://www.monoprice.com/products/pr...#specification
Has anyone done any reviews on monoprice's component cables or can anyone shed some light on whether there is truly a $75 difference in the cables.
Blue Jeans
Monoprice
Works quite well and cheaper than either of the two companies
