Originally Posted by
markrubin
my gosh this gets so confused:
-there is no difference between 1080i/1080p [for all practical purposes] as long as the 1080i is properly deinterlaced
ONLY when you compare 1080p24-sourced material that has been correctly interlaced to 1080i60 and can therefore (hopefully) be correctly deinterlaced to 1080p again. However, once 1080p60 cameras become commonplace, the only way to transmit that WITHOUT LOSS would be 1080i120 (debunking your 'no difference by adding this caveat). And digitally rendered movies, as wella s 1080p movies (LOTR, Shrek and whatnot) can be rendered at 1080p60 onto BluRay ad HDDVD discs. If your TV is only 1080i capable, you WILL lose information (a lot, if it is a non projector, meaning it will downconvert the resolution to 720p or thereabouts, also!)
markrubin
-Flat panel displays are fixed pixel: meaning they display a progressive signal: if they receive an interlaced signal, it first has to be deinterlaced
Correct. And this one is VERY important, and people always forget it. I hate it when someone describes their DLP/Plasma/LCD as being a 1080i TV. It is 1080i CAPABLE, but its native display is ALWAYS progressive, and if its resolution is 720p (or worse, like 1024x768), then it needs to deinterlace AND downsize that 1080i source!
markrubin
-some displays do not properly deinterlace a 1080i signal because of limitations of the processor [ they drop some of the signal]: however many newer 1080 displays have more powerful processors and do handle the deinterlacing properly
Absolutely!
markrubin
-some displays are 1080p but only accept a 1080i signal: this means the 1080i signal must pass through the display's built in deinterlacer: however many newer 1080 displays now accept 1080p directly
This is now VERY uncommon. For a while it was the norm (early Sharp Aquos LCDs and the first batch of Sony SXRD 1080p dumbo-ears versions. Almost every 1080p TV available now, and released in the last year or more recently, also accepts 1080p signal via one or more inputs!
