We just got set up with an Epson 6500UB and a 106" Picture King portable screen with High Power material in a non-light controlled living room with several windows. The projector is about 18' from the screen and we sit between 11 and 14' away with eye height about at the same level as the projector and close to on axis. We set the screen as low as it will go, about 12" off the floor so our eye height and the projector are close to the middle.
At night on Theater Black, with the lights out and the only street light nearby from the side, it is spectacular with reasonable blacks and dazzling whites compared to a Pioneer Kuro 50" plasma TV. In late afternoon with enough light coming in the windows to very comfortably read by, using Living Room, it is quite watchable. Fortunately there isn't much direct light from the direction of the projector.
Moving from side to side, it seems to me that if you are at a comfortable viewing angle, the screen brightness is fine. There is some fall off, but by the time it gets to really being an issue, you're so far off axis that it isn't pleasant to watch anyway.
BTW - we got all this from the Projector People and were very happy with their price, service and delivery.
Bottom line - What's not to like?
