Originally Posted by Joseph Clark
I got the first snaps in place with the screen and frame flat on the floor. In this orientation, the screen and its snaps are face up, with the frame's snap receptacles pointing down. (So, both screen and frame fronts are NOT touching the floor. Under no circumstances should you lay the screen's face or the frame's face onto the floor.) I got the top row snapped and a few on the sides. Then, I was stuck. I just couldn't see or get enough leverage to line up the other snaps. Once I shifted the screen to the wall, it couldn't have gone much easier. I just had to be careful not to let the fabric buckle and sway against anything while I did that.
You have to be very careful not to scratch the surface of the screen. I don't think it can be repaired once the coating is scraped off. If anyone has a better way of doing this, please post. I'm sure it will help a lot of people.
I followed Da-Lites instructions pretty much to the "T" with my 133" Da-Snap hi-power. One bit of advice I can give is to don't try to do it by yourself. I had someone help me. One person would hold/keep the tension on the screen fabric while the other would "snap" the snaps. There are several snaps on the 133" and our hands were a bit sore by the time we were done.
It's worth it though as the screen looks fantastic. I've had it for a few months and I'm still thrilled with it. I just can't wait for my new RS-1 to come in.
.Ken
