Originally Posted by Fat Dave
Yes, you are correct with what you've posted, so I must not have explained myself very clearly.
The quoted reference pertains in particular to my setup, having the projector so far behind the first row. Even though the projector is only 13" above eye level, having the projector so far behind the viewer creates greater angles between the two incident lines than would a placement with the projector closer to the viewing point. This is particularly notable at the sides of the screen in my setup.
I hope that clears things up a bit.
No disagreement! In your case the 'relevant angle' does indeed vary significantly for different points on the screen. I was just wanting to make the point that IF the eyes were fairly close to the pj lens, then this variation would not exist for any point on the screen. But we all live with the practical limitations of our own configurations. Still, as JC says, even if there is some variation over the screen, it is often so gradual that it is not noticeable in practical viewing.
