Originally Posted by deandob
Hmm. I tried that and even turned off all the 3D settings, and re-installed 7.3. No go. Any other ideas from those who had this problem and got it to work? I've gone back to PDVD v6.5 which although only plays half my HD DVD collection, at least renders a decent picture.
I may have to wait until the final release of PDVD 7.3 comes out, or try the trial Nero player.
I'm assuming you are using AnyDVD HD. Have you tried ticking the "disable menus for Canal" option for those titles which won't work in PDVD 6.5? I did that with one title which wouldn't work and it fixed the problem even though I don't think it was a Canal title, but I'm not sure it works for all of them. I think the problem lies with the menuing setup rather than in actually playing the content.
The only alternative to be able to watch all titles under PDVD 6.5 is to modify the xpl file to remove everything (even the nav stuff) but the feature and the desired audio track, however that requires the files on a HDD.
