Originally Posted by
squale
how much is this add-on and what software do you need in the computer to use it? what minimum computer specs do you need to run these videos at 1920x1080?
PowerDVD Ultra from Cyberlink $99.95
For it to work well you need either a mid-level or better AMD X2, a mid-level Core Duo 2, and an Nvidia 7600GT with HDCP... you may get buy with less but for it to really do its thing well, the more CPU the better. The 7600GT is just right and fairly cheap. I have the MSI NX7600GT Diamond Plus HDCP and AMD 5000+. it works great. When I can get a Blu-Ray or combo drive for cheap I will add it as well. This PC does Home Theater great!
Below is a bill of materials on my HTPC Careful shopping should beat these prices.
HP Pavillion m7640n AMD 5000+ MCE $839 after rebate
ATI Wonder 650 $130
7600GT HDCP $200
XBOX Add-on $140
PowerDVD Ultra $100
D_link Wireless USB Nic $69
Total $1478
