from the misc file:
1) There are no screws with the card as with the NEC OEM plates. Not a big deal - just means you must purchase some or remove the screws from the NEC plates. I had originally thought the NEC plate screws could not be removed, but after examining them closely, it appears you can remove them by inserting pressure on the end while using a screwdriver on the other - just takes a bunch of turns and a little time.
2) I assumed that if you had this connected to a monitor (I know several people have 2 outputs - 1 to Projector and 1 to smaller HDTV monitor) that it would pass audio through the audio output from the HDMI/YPbPr source.
Ok...when you stop laughing, I know....bad assumption on my part which I could have figured out if I had realized there was no audio connectors on the card pictured in the thread - but I had assumed there was for so long, I didn't really think to look for it.
If you are in a similar situation this means you need to totally revamp your audio to the monitor for things running out the NEC - something I am not sure how I am going to deal with it at this point.
3) I am having an issue with the output of these cards through the ISS to a transcoder and into the monitor via YPbPr. I have had a KD-VTCA3 on the output of the NEC to convert it to YPbPr for some time and knew I would eventually replace it with something better.
The problem seems to be the KD-VTCA3 does not like the fact that this signal has already been transcoded once into RGB. I have to assume this is the case - and not the moome ISS card - as I saw the same issue when I transcoded a YPbPr signal PRIOR to running it through the ISS and back out through the Second transcoder to the monitor. I had thought it was the original transcoders and hoped this card would solve the issue - but it appears the issue is in the second transcoder converting a signal BACK to YPbPr as one conversion from RGB devices into the ISS seem to work fine.
So, does anyone have any great suggestions for a Transcoder to replace the Key Digital KD-VTCA3 that will play nice with the Moome card and other sources that have previously been converted to RGB?
Now if moome would only make an output section for the ISS that would output YPbPr
