i don't mean to be negative here. this question is asked in earnest. a lot of the lengths that we go to for sound isolation, etc are kind of extreme and they all make logical sense but i wonder if there is any evidence that some of these things make a noticable difference. many of the techniques we use are not easy to A/B compare. it is not like anyone has built 2 identical theaters and only done sealed lightboxes around their ceiling cans on one of them to see what the impact is for example.
i am in the midst of framing on my theater and i am faced with decisions and while i can't argue with the logic of any of these ideas i have to wonder if some of them are worth it. has anyone actually built a stage that was not full of sand then later filled it and found a noticable difference? when i sit upstairs i wonder how noticable the impact on sound isolation is from green glue or light boxes compared to simply double sheet rocking or using common construction adhesive? i have read the tests on the green glue web site for example and there is no doubt it is measurable but in the context of a real theater in a real house with doorways and other things inhibiting sound isolation i wonder if it really makes an impact. lugging thousands of pounds of sand to the basement is non-trivial so i have to wonder if i would know the difference. on the other hand i am sure that if i did i would feel like it made a difference whether it did or not so maybe some of these things are just piece of mind and knowing the job is done right?
i will come clean and admit that i don't believe in magic speaker wire that keeps my electrons in phase either. i guess i am a bit of a cynic after all
greg
greg
