EDIT: This post has been updated with additional measurements and information.
After being asked to do the first virtual AVS interview at the Expo where you guys asked the questions and then I cornered the reps from JVC and got them to respond, it's interesting that someone has asked me to post the first anonymous AVS projector review- of the RS1 (EDIT: it's actually an HD1) no less!!! This is the info that I have so far and more will be forthcoming (probably after Christmas). Btw, this isn't a joke it is from a reputable source and someone who I can vouch for who doesn't want to post here.
Picture of the unit:
Picture of the unit label:
Note: Measurements below were measured at the middle of the throw and with 21hrs on the bulb.
on/off CR:
12000:1 middle setting (note: I assume this means OOB "natural setting")
13000:1 user1 setting. (note: after some adjustments to improve D65 tracking)
(note: no significant change in on/off CR with lamp setting).
Modified ANSI CR (using Greg Rogers methodology):
258:1 normal lamp setting.
260:1 high lamp setting.
lamp setting on high increases fan speed and noise noticeably.
Lumens:
637 lumens on high setting
535 lumens on normal setting
CIE x,y primary and secondary coordinates:
R 0.658 0.341 (rec 709 r - 0.630, 0.340)
G 0.297 0.688 (rec 709 g - 0.310, 0.595)
B 0.141 0.053 (rec 709 b - 0.155, 0.070)
C 0.209 0.326
M 0.326 0.155
Y 0.447 0.543
Updated measurements:
Modified ANSI CR yields repeatably consistent numbers of 270:1 (273:1 max) at mid throw.
On/Off CR was remeasured using multiple instruments and many measurements (to make sure no samples were in error or that there was a significant deviation between readings). The repeatability and consistency between measurements and between instruments indicates that these are accurate numbers folks.
On/Off was remeasured at 12000:1 within a few percent each time (Initial 13000:1 reading may have been in error).
Modified ANSI and On/Off CR at various throws:
Max Wide
ANSI 285:1
On/Off 10100:1
At Max Tele Zoom
ANSI: 245:1
On/Off: 13733:1
Verbal description:
"But OMG, the depth and the detail. And when TheaterTek ends and the logo comes back up it's this amazing graphic in a sea of black. I can hardly see the screen.
The Pearl looks just OK compared to this. I'll take 12000:1 without DI over 15500 with DI any day. And very very little corner brightening
OMG is it crisp.
I doubt anyone who has one on order is going to regret it."
Additional convergence info:
Within 1/2 pixel in the center and consistent across the image
Shading:
OOB Shading/white field uniformity is not perfect, a little coloration is noticeable.
on/off CR:
Lumens:
C 0.209 0.326
M 0.326 0.155
Y 0.447 0.543
Max Wide
ANSI 285:1
On/Off 10100:1
At Max Tele Zoom
ANSI: 245:1
On/Off: 13733:1
Verbal description:
OMG is it crisp.
Shading:
this is actually sad news, not much reason to "upgrade my Pearl" if at all now.
