AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Can you charge a PS3 controller with your PC's usb ports?
Can you charge a PS3 controller with your PC's usb ports? - Page 3
post #61 of 66
http://www.amazon.com/RCA-WP2UWR-USB.../dp/B005IPMIBQ
This one looks better...
http://www.amazon.com/Belkin-Outlet-...ref=pd_vtp_e_1
post #62 of 66
As others may have posted, I have researched on other forums that the PS3 controller lights may not have to be flashing in order to know that it's charging up properly.
I have a couple of Motorola cell phone chargers I want to test this theory with. Though, I'm afraid that if one of them does work with no lights flashing on and off, will it overcharge the internal battery and cause damage (like exploding)? Being that the controller isn't communicating with anything like the PS3 or a laptop which enables the flashing lights.
Thoughts anyone?
post #63 of 66
I have three controllers that I've bought over the last few years, all of them flash until their done charging. When they are full they stop charging automatically and the lights go out, so you know it's done. Not only does automatic charge cutoff save the battery, it allows you to use the controller plugged in for as long as you like without harm.
If you're gonna charge a PS3 controller with a charger that is not using the USB power standard, then you might make a problem for your controller.
post #64 of 66
I couldn't get mine to charge via a ipad charger or a usb slot on a powerboard. But pc worked fine.
Also, this thread has been running for 7 years. Cool
post #65 of 66
Not really running, just brutally resurrected every once in a while.
post #66 of 66
I bought one of these.
http://www.amazon.com/gp/product/B001KYV9AK/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
And it comes with another charging cable so you can charge two things at once. With the additional length of its power cord, you can easily use a DS3 while it's charging.
  Back to Forum: PlayStation Area
