Originally Posted by stefanpaulmayer
dear amir,
as others have now expressed their desire for the audio fix too, I would really ask you to please get back to MS and tell them that their customers actually want the audio-update SOON and don't care about other issues for now. if the update is really ready to go, I really don't see the necessity of holding it back until the playback issues have been dealt with.
regards,
stefan
dear amir,
regards,
stefan
We won't hold the release back forever. And believe me, given the fact that half the team works for me, when I tell them how urgent it is to get the audio fix out, they "get it." They are working very hard to get the release out and with high quality. I know this doesn't mean much to you all waiting for the fix, there is only so much I can push a team which is working around the clock.
. No, there are no "quiet" drives in the new SkU. The drives used there are the same as what is used in the current systems.
My understanding was that you start with what is now called core which is good old DTS at up to 1.5mbps, 24 bit and 48kHz. If you use DTS-HD HR, you add HR extension packets to the core. If you use MA you add MA extension packets to the core up to insane bitrates. You cannot decode HD from MA...
). If we don't do this, the content might dry up at the source and that would not be a good thing. Hence the other reason we are keen to get out title compatibility fixes.
