Originally Posted by
dialog_gvf
Up until now, TL was a layer on the "other" side, wasn't it?
Are they coming up with a true third layer here, one that is closer to the surface rather than deeper? That would be a non-DVD replication process.
amirm
The third layer is on the surface of one half. So no, nothing is on the actual surface of the disc. We are still talking about two .6mm halves being fused together, yielding faster cycle time than molding a thick substrate as BD does. And we still enjoy the same natural protection a deeper recording system provides.
But you are right that is not precisely the same process as current DVD. It adds some level of complexity. But these discs will still be cheaper and easier to produce than BD-50
I think there is some confusion about where the layers are in DVD and HD-DVD. In DVD and HD-DVD dual layer discs, a layer is molded one the surface of each 600 micron thick part. These parts are then bonded
back to back with the molded pits in the center of the disc using an optically transparent 'glue'. When done so, the two pit layers are only microns apart in the center of the disc (55 +- 15 for DVD and 20 +- 5 for HD-DVD). Both layers are read from the same side of the disc.
So the HD-DVD stack order from laser entry surface is:
~600 micron polycarbonate
Layer 0 pits with partially reflective coating.
20 micron Spacer layer (optical grade 'glue')
Layer 1 pits with fully reflective coating.
~600 micro polycarbonate
For DVD-18 and HD-DVD > 2 layer combination discs, you mold a second layer on top of the first layer on each part using a special process (BD50 requires this for its second layer).
So a HD-DVD- 30/DVD-9 combo or (DVD-18) stack would look something like:
~580 micron polycarbonate
20 micron Spacer layer (2P or other material)
glue
~580 micro polycarbonate
A HD-DVD-51 stack would probably look like:
Layer 1 pits with partially reflective coating.
Layer 2 pits with fully reflective coating.
