AVS › AVS Forum › Audio › DIY Speakers and Subs › Woofer Noise with my IB
post #1 of 10
OK. I'm stumped. I have an IB that I've been running for about three years. It's four PE IB15's running off a Apex Senior plate amp (about 240W/8ohms). Recently while watching "Lucky Number Slevin", in noticed a rattle coming from the woofers. There's a quiet elevator scene where this rattle was exposed. I've never heard voicecoil rub before, so I don't know if that's it. But all four woofers make the noise. In troubleshooting, I've found that the woofers only make the noise if they are braced, like mounted in the manifold. The latest thing I've done is mount only one woofer in the manifold (to take most pressure factors out of the equation), and the woofer will still make the noise, only it takes more power to cause it.
I'm presently running an LFE sweep (125Hz-20Hz), as the test tone. I don't believe I'm hitting Xmax or clipping the amp (signal looks clean on scope). It's possible this noise has been there all along, and it's just been masked by other more active soundtracks (or lower listening levels). For example, in SW Ep2, the early explosion reveals the noise easily in the attic, but it's unheard in the listening room due to the other explosion sounds.
If anyone has any ideas, or has experienced the same thing, I'd like to hear it. I was going to post this over at the IB Cult page, but traffic over there seems to have died down (unless they have a new page that I didn't find). TIA.
post #2 of 10
post #3 of 10
The forum was moved to a different host and domain 18 months ago. Unfortunately I was unable to put a redirect before the old host took down the forum. It's pretty easy to find us with a google search.
What you're hearing is most likely the amp going into 'hard' clipping. The amp has less than 1/2 the recommended power for those drivers (140 watts each)
post #4 of 10
Yea, I found the new IB site a while ago. I'm presently powering just one woofer with the plate amp while I troubleshoot, so I don't think the amp is clipping. The woofers should get to Xmax before 230W in 'free air'. I've moved to a low frequency test disc, and it looks like signals around 25Hz get this noise to appear. Sounds like little fireworks behind the dust cup I'll check the signal going in to make sure it's clean. I've made sure it's not lead slap by moving them a bit back as the woofer plays. Oh, and the distortion is there even with the woofer unmounted, just takes a little bit more power to start. Guess it means I have four bad woofers if the amp signal is clean, huh?
post #5 of 10
Hmm..I wonder if this is relevant at all?
http://www.hometheatershack.com/foru...ver-noise.html
post #6 of 10
Wild,
Wow, that was an interesting link. Thanks. It does sound like our problems may be the same. Everything external to my woofers seems to be fine. The DVC and the IB series are identical build-wise. I have a DVC15 in my closet, and a friend with the same IB as me. I'll run the same tests with all those woofers and see what I find. This may be a problem that shows up after a couple of years with these woofers.
post #7 of 10
If it's a piece of loose adhesive you should hear that rattle by simply tapping on the cone.
post #8 of 10
I've had one partly separate from the spider before. Took me a bit to figure out what it was until I fully exerted the driver outward by hand & noticed the tear about half way around the VC. You couldn't see the tear with the driver at its resting position. Some of the epoxy broke loose from the VC & than tore the spider.
I was lucky enough to be under warranty though & PE replaced it without a complaint.
post #9 of 10
Well, looks like it may be an amp problem after all. I brought the woofers back to my living room and really worked them over with a new plate amp, and I mean really worked them over. No rattling noises at all (And I was just going to make sure they were all bad!) But turns out I believe they are ok. So I turn my attention to the rest of the system. Funny, back when I was doing the LFE sweep, I noticed the distortion started at the same point on the volume setting (50), whether there was one or four woofers wired up. I thought it odd (since a single woofer taking all the power is working much harder), but I chalked it up to pressure issues within the manifold. Now it appears to be a clear clue that the amp is faulty. I own an early version of the Apex Senior. Some may remember that these initially came with power supply caps whose voltage rating was too low for that amp's power rails. So the caps become leaky. I just checked mine and sure enough, they have started to leak. I guess I now know what kind of distortion they can cause when that happens. So I'll order some new ones, and see if that fixes my problem. I'll report back when I know for sure. Thanks for all the help and ideas. I'm glad I won't be having to ship back four 15 inch woofers to PE.
post #10 of 10
Got the new caps installed, and all is good to go. Now I just have to tame all the other house rattles I discovered while troubleshooting my problem. Seems the nearby windows just can't take the pressure.
