AVS › AVS Forum › Display Devices › Flat Panel General & New FP Tech › FAQ & RULES LINKS_ Plasma & Panasonic Plasma FAQ - Read First!
FAQ & RULES LINKS_ Plasma & Panasonic Plasma FAQ - Read First! - Page 9
post #241 of 1295
For a PWD7UY
Where can I find the hours used
post #242 of 1295
Originally posted by Taisin
For a PWD7UY
In the service menu. For instructions on how to get into the service menu, click on the link in the first post of this thread.
post #243 of 1295
Thanks mj
Also, the top of my stand (STO7K) does not flush with the bottom of the display.
There is a about 1/4" gap. The screw holes on the two poles do align with the screw holes of the display. I wonder if that is normal.
post #244 of 1295
This is the same with my pwd7uy and the same stand so I would guess that it is normal. The plasma must be resting on the top of the metal poles.
post #245 of 1295
What digit is it in the serial # of the TH-42pwd7uy represents the year of manufacture. I saw it posted a few days ago but can't find it now. TIA
post #246 of 1295
Originally posted by vancouver
I have a Panasonic th-42px20 and have notice lately that there is a black line about 1 pixal wide going from the very top of the screen to the very bottom. Does anyone know what this is? Is it normal for a whole line to go out like that? The Plasma is still uner warrently so I am wondering if I should get it fixed or not.
I had the same problem with one of my pana displays in my store, though it was a green line. It was a defect and panasonic covered it under warranty.
post #247 of 1295
Manufacturing date is below the Model number description on the sticker e.g. :
SEP 2004
post #248 of 1295
Has anyone received a new S-Video blade yet for Panasonic 7UY??
post #249 of 1295
Check your PM.
post #250 of 1295
Received mine today. Took about 2 months but it's here, excited to see how it turns out.
post #251 of 1295
I was just testing the speakers out connection on the PWD7UY
but couldn't get any sound out of the speakers.
Volume was at about 22 and no mute.
The manual seems to suggest it would only work with the designated optional speakers.
Anybody has the experience or suggestions.
post #252 of 1295
I connected a couple of cambridge soundworks cube speakers to the speaker outputs and they worked beautifully with my pwd7uy.
post #253 of 1295
MJ
So no particular settings required?
Also, I was using 8 ohms speakers
I would try other speakers and see what happens.
thanks
post #254 of 1295
MJ
thanks
Just be sure to use very efficient speakers.
post #255 of 1295
In case anyone is interested, the pq through s-video actually got worse with the new blade installed. There are still the same dancing lines, but now add a nice upward scrolling horizontal bar through any black screen. Very disappointing, i've had another issue with the panasonic that needs to be taken care of by them but they are impossible to deal with/contact. I'm regretting buying the panny monitor.
post #256 of 1295
Hi:
Thanks guys.
Turns out that I didn't plug the wires deep enough to the connectors on the panel.
It's doing fine now.
BTW, I really enjoy the PQ of this unit.
A bargain.
post #257 of 1295
IM so lost....sorry if this is redundant but the more I read the more confused I get. Heres what I want:
a)42" plasma
b)HDTV ready ( not built in I have Directv HD rec)
c) looked at the th-42phd-7uy but since im using it im my bedroom prefer builtin speakers
I looked at the 42-xvs30up & the 42px50up?? Such a wide spectrum in price I am obviously missing something.
Please advise, thanks
post #258 of 1295
The Onyx Models (42XVS30up - 50XVS30up - 65XVS30up ) are the High-End Series from Panasonic and supposed to have better electronics. To my eyes, PQ was the same compared to the regular models.
post #259 of 1295
So Bruzzi, for my need of plasma TV which is best fit...sorry for the novice type questions..........it seems no need to go with thexvs....which means im left with either ohd or px......I dont want EDTV, since i have HD direct
post #260 of 1295
I would get the XVS series only because of the Design. Otherwise the Commercial PH7UY or the HD 50/500U "should" have the same PQ.
post #261 of 1295
a)42" plasma
If you looked at the TH-42PHD7UY and like it, but need speakers, you can always opt to add the speaker kit (Panny Part# TY-SP42P5W-K)
post #262 of 1295
Thank you all . lot of help I think ill go with the 7uy & add the speakers as suggested,,,,,whats not to like Unless you guys tell me there a better bang for the buck on a 42" plasma I should consider ?
Thanks again
post #263 of 1295
Thanks again
As much as I hate to do this...
Before buying the PHD7UY, you should read the following long thread that talk about some problems with the "7UY" series - which affect more the PHD than the others:
http://www.avsforum.com/avs-vb/showt...hreadid=479574
post #264 of 1295
Bruzzi,
Thanks for the info.....I also am concerned with the 7uy any service needs would be handled as a carry in, where as the px50u would be in home.
Can you shed some light on why I am finding the px50u ( newest generation) cheaper than its predecessor px25u?? seems odd to me
thanks as always
post #265 of 1295
Bruzzi,
Did you check the Service Center Locator already???
http://www.pasc.panasonic.com/WhereT...cer.asp?Pass=1
Maybe there's an Authorized Repair Center close to where you live.
thanks as always
It's been like that for the last couple years as the cost of production are decreasing.
So prices of Plasmas are falling down each year. Even with new features/technology.
And they'll keep going down.
Check out the following thread:
http://www.avsforum.com/avs-vb/showt...hreadid=533594
post #266 of 1295
All true, but it also seems fair to suggest that the PX500U is the real successor to the PX25U. The 50 series has a stripped down feature set compared to the 25's, part of the reason Panasonic could drop the MSRP so drastically.
post #267 of 1295
Hi is the th-42PX50U out yet I think this is the one for me
thanks
post #268 of 1295
hi all, i was trying to get into the service menu of my pd25u with the instructions on bruzzi thread but could not, can some tell me step by how to do this, and would having a cable card in my unit make it harder to do?
post #269 of 1295
david8613, there's another member using CableCARD that can't access the Service Menu. So try removing the cable card to see if It works.
post #270 of 1295
Hi all:
I am considering using a VGA/component breakout cable connection to utilize the PC input on PWD7UY. Are there issues with it like color etc..
