Just ordered the HD7UY
Cant wait. Now I need to get prepared. I have 3 things I want to run to the monitor:
1. HDTV Motorolla STB
2. XBOX
3. HTPC
I want to use VGA for the HTPC.
I will be using component for the other 2. I assume since Im using the VGA for the computer, I will need to do some component switching via my pre-amp.
That being said, I looked at the pic of what comes with the panny stock and it looks like the component in "SLOT 2" are BNC connectors or am I seeing things and its RCA? Is that the case? If so it looks like Ill have to go out and purchase some cables...
I assume they make BNC-RCA component cables if I need them?
EDIT: After looking around for a couple more hours I found the answer to my question. Since I have the commercial model, its BNC connectors. Looks like Ill be making a cable purchase
