AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Runco XP-65DHD 65 inch 1080p plasma monitor is here.
post #1 of 7
So if it is a 65/1080p then it must be a Panasonic (pf9uk) glass, correct? I think they are bundling it with their DHD video processor. What a setup, if my assumptions are anywhere near correct it should provide interesting competition to the coming Fujitsu 65/1080p Plasma (also using Panasonic glass) with their new AVM III processor. Choices, choices. Wonder which one will take the prize for being the most expensive and which will actually be superior?
post #2 of 7
post #3 of 7
My bet will be on Runco - for biggest dollar per inch cost!
post #4 of 7
Runco makes their own glass
post #5 of 7
I believe that this in incorrect.
post #6 of 7
Is this not the same TV as this?
post #7 of 7
I've got a ten spot that says all three use the same glass.
