Originally Posted by
ChrisWiggles
I know. It's a ridiculous claim. And as an ISFer you should know this intimately.
It's the DISPLAY that is obscuring the detail via light spill! Goodness.
If you can see the detail at the screen (this means that the projector is displaying the image), but you cannot see the detail when you move away from the screen, how can you call that "light spill". All projectors have light spill, some systems perform better than others.
You are missing the point of my test/example. If you suddenly replace a full white field (full screen is 100 IRE white) with a black to 20 IRE stair pattern (very low APL screen) (
BTW, with no white there is NO light to spill). If all the steps are displayed, but it takes you a few seconds or minutes to see all the steps, how is that an issue of the projector and not the eye?
That's the system's CR. Measure it with a light meter.
You totally missed the point here, no it is not the
systems CR it's
yours based upon the systems numbers.
Did you try the shadow puppet test? Use the same pattern and try to make shadow puppets in the dark parts where you can no longer distinguish the bars. Or see if you can see the screen boundary as distinct. According to your unbelievable logic seeing that would be IMPOSSIBLE!
Yes, you can make shadows, but when I properly calibrate a projector, you can see all the bars. If the bars are not being displayed, black level is set too low.
I'm sorry if I'm frustrated here, but this is really basic stuff. I can understand novices and newcomers not understanding contrast ratios, but not trained ISF calibrators and professionals.
It clearly seems that your frustration is from the lack of understanding what others are saying and or your inability to express your specific point to where others understand.
This is bordering on unfathomable to me that otherwise intelligent people can still be making these claims that we can only see 200:1 across a scene. So by this logic nothing beyond 200:1 ANSI or instantaneous CR is useful. Incredible.
You still don't get it. It doesn't frequently happen, however the display can, at times, out perform the ability of the eye to adjust to the changing light levels.{quote]DO A TEST. It's not hard. Not a single person has done so except Darin and myself. Gee, I wonder why... because it immediately and unambiguously disproves this nonsense about 200:1 CR being all we can see (or pick your random figure: 130:1, 100:1, 250:1, 300:1, we've seen them all pulled right out of thin air, they're all equally ridiculous).[/quote]Have you done any of the tests here? Try them. I am not subscribing to any global "all we can see" specific CR. I have given clear examples of situations where we don't see beyond the 200:1-300:1 CR, it happens. Is that the limit of our range, absolutely not. It usually takes the eye longer to adjust to dark vision than light. More examples, be in a dark room for 2 hours then walk outside into the bright noon time sunlight, any white clipping? drive in the daylight and drive into a tunnel, do you have a temporary "night blindness" can you instantly see all the detail in the tunnel?, then coming out of the tunnel, a little white clipping again?
If your point is we can see a range more than 200:1 across a screen, I would say yes. But, if you are really talking CR, it should be in close proximity, white next to black. A good test would be an inverse Pluge pattern, full white field with small black stair step window.
Glen: can you see the difference between a FP display with an ANSI of say 200:1 and one much higher than that (such as a 1-chip DLP)? I mean come on here, you can't honestly be claiming that there is no difference there.
I haven't been able to do an A/B test. It also depends on what part of the picture you are talking about. My CRT (9500LC) might have a 120-130:1 ANSI and a very high ON/OFF CR, it has better low APL performance than brighter projectors with higher ANSI CR, but lower ON/OFF CR.
