Originally Posted by
HoustonHoyaFan
Why are you talking about ANSI CR? I have said time and time again that there is
no direct relationship between the HVS CR number of <300:1 and the ANSI CR number of 300:1.
I used ANSI CR because it is a pattern that you can find on a test disc and I have explained multiple times that there are patterns were we can see more than that pattern. Not sure why you went off on your "no direct relationship" thing since I didn't say there was any direct relationship there. You also seem to want to ignore questions like whether you could see a difference there or like: "If MrWigggles image was put up with 500:1 simultaneous CR and that was improved to 4000:1, do you think you would be able to see that the 4000:1 was better?"
HoustonHoyaFan
" Thats like comparing 300 meters with 300 seconds. It does not work, and you know that. Given that the Ruby does ~300:1 ANSI on a 4x4 and 80:1 ANSI on a 6x6, I would speculate it is ~2:1 ANSI on a single pixel checkerboard which is the closest analogy to a HVS CR IMO.
So, is your claim that people can't see more than 300:1 in a single pixel checkerboard, or is it that people can't see more than 300:1 in any single image, or something else? Please clarify why you mentioned the single pixel thing above and if your claim of 300:1 is for single pixel patterns, why you would apply that to images that are much different?
HoustonHoyaFan
I guess you are right. I don't understand, the scientists are confused, all the researchers who have mapped the bio structural and biochemical limitations of the retina are clueless.
If you understand, then why not answer the question about MrWigggles image? And you should be able to tell us whether your position is that people would not be able to perceive improvements beyond 300:1 simultaneous CR in any image or not. If that is your position, then it should apply to any image I use as an example, not just some special ones that are more limiting than those.
And do your claims apply to things with movement or only static images? If your point isn't that we are limited to not seeing improvements beyond 300:1 at once, then what is it?
Raul GS
Darin, the problem with your test is that you are not able to isolate a critical confounding variable. You provide no means to determine if the iris in the eye has remained static through your test; i.e. any change in the iris would invalidate your findings.
Nope. I have gone over multiple different tests that can be used and even if the iris moves in 1 millionth of a second and I can't tell, it would be those who are saying we couldn't perceive improvements beyond x from a display who would be wrong for applying things incorrectly. When I am looking at the scene from "Sin City" that I talked about in my article about CR with the projector zoomed down to less than the size of the screen (to create a border between the image and the screen edge) and I can make out multiple levels of bright and multiple levels of dark, sure it is possible that there are some extremely quick transitions in the eye that allow me to perceive all of those and not just crush things that measure outside the 100:1 or 300:1 range, but that just validates the point that the images need more than that for simultaneous CR before we could not perceive any improvements beyond that CR. As I pointed out before, anybody looking for the largest range needs to have transitions in both directions and that perceiving even 50:1 below and 50:1 above some reference would mean a total range of 2500:1 there.
I think I'm repeating myself, but we should remember that projection systems can do much higher simultaneous CRs than their ANSI CRs. The ANSI CR test is a more difficult one than some others. A projector with 100:1 ANSI CR and 10k:1 on/off CR should be able to do over 500:1 simultaneous CR in lots of images.
--Darin
