My situation is that I have just finished my HT room. My rear speakers in the 7.1 set-up are located per THX recommendation, not Dolby's. They are about 24" apart on the center of the rear wall. It will be very difficult, expensive and time consumming to move them.
While in the front row, I can barely tell they are there, mainly due to "rear-to-front sound reversal". In the rear seats they sound much better. Is there anything I can do electronically to help the situation? Change delays or volume level slightly so the sound reveresal does not occur?
The speakers are M&K in-walls that match the rest of the system.
Please help me if it is possible.
since they are in-wall but thats what you should do. You could leave them where they are and buy a THX select2 or ultra2 receiver but of course that is more expensive unless you can return the denon etc...
