Hey all,
So I really wanted to start dumping a lot of my remaning S-VHS and VHS tapes onto DVD very soonand was wondering what would be the best machine to look for? I know I probably won't get a new one but was hoping I could look for one on Ebay...even a "pro" one. Is there a brand that I should look for or stay away from? Or are they all pretty much the same?
Sorry for the "newbie" question. I also didn't know where a question like this should go because VHS is "obsolete."
!) - After lots of tests and alternatives, I've come to what 'seems' to be the best solution: use a JVC - HM-HDS4 for playback, that I originally had intended to store a few tapes at a time on it's Hard Drive (!) and then pass them to the Tosh RD-XS32 (more of that later) to be edited and finally burnt ... I then discovered that the XS32 actually accepts a direct DV link from the JVC (one of, as far as I'm aware, only a couple of S-VHS decks that has a DV-out, the other one being the JVC SR-VS30, the one with the mini-DV on the other side) without necessarily having to record to the JVC HD, but simply go straight to the Tosh ...
