AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › PDP-4270HD Issue\Questions
post #1 of 3
As searching is currently disabled... I will just ask,
Has anyone experienced vertical video banding on the 4270 or 4271? I seem to be getting some and am not sure if it is panel or source related. (kind of doubting source as I have used the same source with two other panels and did not notice any banding at all)
Did anyone else need to disable the PureCinema feature because the picture would re-adjust what seemed to be the brightness intermittently after scene changes?
post #2 of 3
My Pioneer 4271 has had problems with the screen shutting down and displaying the message: "Start up - Please Wait"
I am lucky that it is only three days out of the box and very returnable for 27 days.
No other problems noticed but again its only three days out of the box.
post #3 of 3
i have the very same banding - though its more like patches on the screen - have you done anything about this?
I also get the changing brightness - happens quite noticeable on starwars 3 chapter 20 as the ship enters the landscape - the left side changes brightness.
Also as i use my xbox 360 to watch movies i cannot seem to turn the pure cinema off!
