Originally Posted by MikeSM
ZFS is great. We use it at work and it's fantastic from a performance and management perspective. The only problem I have with it is that it's part of Solaris. Not that Solaris is a bad OS, but the hardware and driver support for Solaris is tiny compared with Linux. Port multipliers don't work on Solaris as far as I can tell, and a lot of consumer hardware just isn't supported.
Solaris is generally used as servers; not as desktops and by limiting the supported hardware you do get better reliability.
I understand your point that; as I'd like to see much broader support from the OS than I do.
Still, for what I use it for it works
Hopefully the FUSE project will make a lot of progress and we'll be able to see ZFS under Linux as a viable solution. It's a lot easier to manage, even more so than using EVMS which I find works well.
ZFS is in its infancy; and over time I'm guessing it will only get better.
Cheers,
