My New Year's Resolution is to improve the bass on my HT. I've started building my own subs but I've also decided to try to treat my 1800 cubic foot below grade theater room. My first thought was to put a bass trap in a nasty corner. The GIK Acoustics 244's seemed ideal (and only $60) but I wanted to try the DIY route first (mainly because I had a lot of extra insulation lying around).
After doing some research I figured I would try to build a 4' x 2' frame out of 2x6's and stuff it with compressed fiberglass insulation. My goal is to get a 4x compression into 6 inches. From the pictures, you can see it kind of poofs out a bit but hopefully I'll be able to fix that.
When I'm done I'm going to show before and after plots for my room. Dealing with the fiberglass has been a pain so I'll probably get two of the 244's as well and can compare / contrast.
