AVS › AVS Forum › Display Devices › Display Calibration › Samsung Calibration Failure
post #1 of 170
So I bought one of these TVs a couple of days ago. I decided to calibrate the TV properly and went to the service menu. Now the first option there is Calibration so I clicked it and some new options appeared: AV Calibration, Comp Calibration, PC Calibration and HDMI Calibration. I use the TV mainly for gaming so pushed Comp Calibration. Now all these settings had "Success" written next to them and when I pushed Comp Calibration it changed to "Failure"?! Now I can't change it back no matter what I do. Any help would be appreciated.
Sorry made the earlier post in the wrong sub-forum...
post #2 of 170
Greetings
What exactly did you think you were "calibrating" by activating those items?
If we changed the word from calibration to "self destruct" ... would you still press those?
When activated, the TV looks for a specific test signal being fed by an external generator. If the signal is not there ... the test routine assumes that what ever is there ... a cartoon ... a news program ... is that very pattern and adjusts accordingly.
You can't fix this yourself ... without that pattern. This disaster is your making and you should just tell samsung that you messed around and pay for the repair job needed on the TV.
Regards
post #3 of 170
Well the picture is still good. It seems that it only calibrates colors and doesn't even affect the Game Mode (which I always use anyway). I also copied the sharpening and RGB as well as ADC settings from RGB (Scart) connection. The picture is now better than it was before (at least it seems that way) and doesn't have that annoying edge enhancement. So since you're a professional calibrator can you tell me
1. Should I be worried even if the picture is now better or at least as good as it was before
2. What settings does the automatic calibration affect? Since the signal and that calibration feature obviously affect settings that can be set manually anyway
3. Do you have any other tips for calibrating the sharpening and colours?
4. The calibration feature seems to be input specific so it only affect component input in this case, correct?
5. Is it just me or does the calibration feature only affect Dynamic mode?
Thanks for your answers in advance. I have calibrated monitors before so I guessed the calibration feature would have just shown me the color settings. Well, now I know better.
EDIT: One more question: If I some day want to get that comp calibration changed to Successful status, can the repair be done on the spot or do you usually have to send the TV for repairs. I mean they would just have to hook up the signal to component and use automatic calibration setting again.
post #4 of 170
Sorry for the double post but I'm writing this with Wii so I can't edit my previous post without rewriting it. I just took a look at some color calibration cards through Wii and all colours seem to be perfect.
post #5 of 170
Greetings
1. If you got it back close for your eyes ... then consider yourself lucky. Some people have not been able to get it back to remotely close.
2. Details of the Calibration function are sketchy ... Samsung does not talk about it much.
3. Calibrate with a test disc ... and with professional instrumentation where possible.
4. It is input signal type specific.
5. Again details are sketchy ... and I don't have any sets around that I want to ruin for such an experiment.
Regards
post #6 of 170
Hey,
Thanks a lot for your answers! However, if possible, I'd still like to inquire about the repair (recalibration): Do the manufacturers usually send someone over to calibrate it or do one have have to send the TV over to them for calibration?
post #7 of 170
Greetings
With the proper test pattern from their signal generator ... it may take them all of 30 sec to undo the "damage" done. Plug it in ... press recalibrate ... and all done.
Regards
post #8 of 170
Originally Posted by Syvere View Post
Hey,
You would have to send it and pay likely since you broke it.
post #9 of 170
Well, after tweaking the settings further and referring to NTSC color, sharpness, brightness and contrast charts I can say that now everything is perfect (at least according to those charts). I want to thank you all for your help.
post #10 of 170
I just wanted to let you know but the Success status CAN be reattained with proper pattern without sending the TV to repairs. I used Avia's Checkerboard pattern with PS2 and now my TV has once again all inputs successfully calibrated. Samsung's Service was kind enough to inform me what kind of pattern they were using. Also in Samsung models the calibration only affects contrast and brightness levels so that also explains why Samsung users always seem to get good picture even though the calibration is a failure.
post #11 of 170
Great to hear ... thanks ...
good they were helpful ...
Regards
post #12 of 170
Cant you restore defaults?
post #13 of 170
No, you can't. You can only restore default settings for normal menu items but for service menu options there is no reset function which is why you should always document the changes you make there. (and not play with the calibration function )
Regards
I really appreciate your help too. Usually people just ignore others' problems. Happy New Year!
post #14 of 170
Hi Syvere!
I've also managed to make this misstake...
What exactly did You use from the Avia? As I understand theres a couple of different checkerboards there...?
I've also noticed that it is possible to get the correct values from other inputs...
Start the TV and select channel 1 or HDMI, shutdown, restart the TV i Service meny, note the settings, shutdown, restart the TV and select AV1 or 2, shutdown, restart using Service Meny and change to correct settings noted above...
This worked for me....
But I've learned the hard way not to mess with the service meny, and absolutly that it is essential to note all settings prior to messing up the set...
post #15 of 170
Hi Syvere and Pexer.
I guess have joined the Calibration Failure club :-(.
As you I have also accidentally pressed the wrong button in the calibration menu.
Syvere, could you help me get Success back on screen, please?
post #16 of 170
Greetings
As the posts say ... try a checkerboard pattern (8 white and 8 black boxes) and activate the process again.
Regards
post #17 of 170
Greetings
Regards
Thanks Michael, I'll give it a try when I get hold of a PAL calibration disc and will let You know if it helps!
A couple of questions though:
- Just to make sure: Using a NTSC material (like Avia) would not help me, right? (I've got a European set...)
- I read somewhere that Samsung takes calibration further using color in checkerboard. Should I not use a color checkerboard then? Or is the calibration only for contrast and brightness?
post #18 of 170
Greetings
You will have to ask samsung those questions.
Regards
post #19 of 170
Hi Michael, Syvere and Pexer
sorry to bother you guys again but I'm still in the dark here.
According to Michael I should use an 8x8 checkerboard pattern to get 'Success' again.
I was just wondering. Can I create one of my one with squares of 240x135 for a 1920x1080 screen?
And what is the procedure I should follow: go back to the Service Menu (OMG) and go to Calibration again?
Please advice (and thanks in advance).
Regards.
post #20 of 170
OH YEAH!!! I'm a 'Success again!!!
My steps to success:
1. Created an 8x8 checkerboard of squares with size 240x135 because my TV is on 1920x1080. My checkerboard starts with a white square at the top left side (don't really know if this matters though).
2. Used my XBOX 360 to display the pattern on TV
3. Started the Service Menu on my TV and went to the Calibration menu.
4. Pressed the 'left cursor' button on my TV remote and waited.
- In the mean time the black squares turned green on my TV but I just ignored it.
- Then the brightness suddenly increased... but I still waited (to be honest I don't really know how long I've waited but it at least 20 seconds I think).
- But then... the TV shows the original picture (the green squares returned to black) and more importantly... the menu shows "Success"!!!
So thanks a lot for all your help guys!
Best regards.
post #21 of 170
Most TV's use a 100IRE (100% white) window pattern to calibrate the A/D converters. I've used this on a Samsung HPS 5053 to fix a problem with low IRE resolution errors on the component input. Use a 480i source. Wait 8 minutes or more untill it finishes with success. If it isn't correct, try again up to 6 times untill it finishes correctly. Wait 10 seconds after power-off to turn it back on. Check all settings in user mode, not service mode.
PS There is NO WAY to adjust tint on component OR HDMI inputs, even in service mode. If I find a workaround, Ill post it here.
post #22 of 170
Thanks for Your response!
What does Your set look like during the calibration?
My turns from the 100IRE pattern to a bright white fullscreen. Just like turning up contrast and brightness to a maximum. Then the process restarts... Sometimes the white portion turns red, sometimes green... Seems neverending! Is this normal??? Im using 100IRE pattern from Avia (one white square on black bottom).
post #23 of 170
Hmmm, this is a good thread. I just bought a new Samsung LN-S4696D LCD TV. I'm waiting to put 50+ hours on it before I do a Colofacts 5.0 calibration on it. This is my first Samsung TV so got the code for the Service Menu and went in a couple on nights ago to explore the options in there. I went into the Calibration menu to see what the options were in there and I guess I hit the Left Arrow key rather than the Menu key just above it as it started going into a calibration process. No keys worked to stop it or get out so I pulled the power cord. Plugged it back in and every thing looks just as it did before - guess I'm lucky here? (Or is there a "Save" key that needs to be entered which I didn't do, or) Still, I may try looking into that submenu again to see if any inputs show failure. If so I'll fire up the Avia disc Checkerboard pattern and run it.
Guess it could have turned out worse!
post #24 of 170
Hello, I'm success again!!
My steps:
- I prepared a 1600x1200 black and white checkerboard jpeg image with windows paint.
- I displayed it full screen with the Wii photo channel.
- I start calibration.
That's all.
post #25 of 170
I came to this thread looking for someone to help me out by telling me how to access the service menu on the Samsung 5053. Although after reading this post it looks quite a scary place to go! But I am willing to risk it because I have a bigger problem!
It's not actually calibration I am initially looking for really. It's because I emigrated from the UK to the US and brought my PAL PS2 (bought in the UK) and all my PAL games (also bought in the UK). I want to use the PAL PS2 with my new (US and obviously NTSC) Samsung 5053 and I hoping the service menu may give me the key!?! I am hoping there is a way to get it to accept a PAL signal.
I may of course be hoping and it will not do that at all so anyone out there who can think of an alternative - like running the PAL picture through a cable box or DVD player or Amp to convert to NTSC or any fancy little gadgets or cables anyone can think of - would be much appreciated.
I know of the PAL to NTSC converter boxes but they cost $150-$200, which my wife is NOT going to let me buy just to run my PS2!!!
Please help!
post #26 of 170
Any takers?
post #27 of 170
What a nice thread
I'm from portugal, and i've got a Samsung 40r74
And for my bad, i've done the PC calibration mistake
Since this lcd is only 720p, what resolution should i put on the screen 1360x768
And whats the dimension of the chess?
post #28 of 170
if i have gone into the calibration menu while the input source was on DTV, how would i bring up a test pattern to change the status to success again? because from what i understand, the calibration menu is in relation to the input being present at the time. i am showing success in all other inputs but the DTV shows failed. Thanks in advance
post #29 of 170
i forgot to say what model i have. it is an australian Sammy model la46m81bdx 1920x1080 integrated DTV
post #30 of 170
I am a Samsung DLP owner. On which Samsung models can you use this process for calibration?
