AVS › AVS Forum › Display Devices › Display Calibration › Samsung Calibration Failure
Samsung Calibration Failure - Page 6
post #151 of 170
Thank you all for help.
I made the first mistake to calibrate AV on watching TV :-(
Then the 2nd, i did the Firmware Reset :-((
So all 4 Sources was without calibration. DTV and HDMI was with good look, but Status at failed.
This one was no problem to calibrate by PC sending 8black/8white pattern with top/left in black via HDMI.
For AV i tried to use my DVD Player with burnt DVD and some images like the b/w pattern and some with colours. Without any funktion.
Now i tried with a lean Wii with pics at SD-Card. First the same like DVD, so i tried to calibrate the colours manually via ADC Target with levels of the HDMI Input. Changed levels to
1st_Y_GH: 128
1st_Y_GL: 100
2nd_R_L: 194
2nd_G_L: 194
2nd_B_L: 194
2nd_R_H: 49
2nd_G_H: 49
2nd_B_H: 49
with this the pic came near to the HDMI with good tolerance. After switch off/on, it was possible to calibrate automatic over ADC Funktion. The violett square was hopping around in 4 positions and avter 20 seconds it was done with success.
I hope this will help all others with problems getting it done.
My automatic results are:
1st_Y_GH: 306
1st_Y_GL: 112
2nd_R_L: 134
2nd_G_L: 134
2nd_B_L: 134
2nd_R_H: 68
2nd_G_H: 68
2nd_B_H: 68
post #152 of 170
I'm successed,the picture turn mormal finally!! Instead run the calibratation process just set 1st_Y_GH & 1st_Y_GL manualy till the picture looks great, Thanks everybody!!!
post #153 of 170
Can someone give us-send us via PM or as a post in here the manual for the Samsung B750 series (LCD panel)?
I saw here many factory sheets for Samsung models...
I got a AV calibration failure (2 years now) and i have still not found how to fix it...
Please...
I need help...
I am desperate...
post #154 of 170
I also accidentally got into the HDMI calibration on my 71 series Samsung.. Although I never got a fail, nor a success.. it just said "HDMI calibration" on the screen and the colors of the screen kept cycling through weird shades and then after about 10 minutes it stopped cycling colors but I couldn't get out of the menu.. I ended up pulling the power cable on the tv.
When I turned the tv back on, all my color settings were way off and using my old color calibrations don't come close to looking the same anymore..
Suggestions?
post #155 of 170
Suggestions?
My friend...
I had the same problem for 2 years...
2 years the same nightmare, 2 years searching and testing patterns, ideas, suggestions...
I also bought the service manual of my TV...
I had no success...
1 month ago i found this link http://wiki.samygo.tv/index.php5/Calibration and i followed axcactly the instructions...
After 2 years my TV was calibrated into success AGAIN...
If you have any questions it will be my pleasure to help you because I KNOW your nightmare about this...
post #156 of 170
I too have accidently run the HDMI Calibration (stupid menu controls!!), I've recalibrated using the built-in checkerboard pattern found in the SVC menu but my picture still seems dim on all inputs...
While in the service menu the image is bright and vibrant but if I restart the TV then the picture is dull, I've managed to get around this by increasing the Sub Brightness in the AVD/WB menu but could someone tell me what their default settings are for a Samsung D6530 please?
Also, do I need to re-calibrate all inputs? (HDMI, AV, Comp and PC?) or can I just leave it calibrated via HDMI only as this seems to have fixed the image aside from the brightness.
To think I was just trying to find a way to turn off the auto dimming
- Rich
post #157 of 170
A AV ADC calibrate was done when on the TV input (analog channel) and it not just failed, it won't allow any further calibrations using a checkerboard (or lattice pattern as Sammy calls it) as their Service manual calls for. According to the SM, Sammy calls for a lattice or checkerboard pattern with the AV input as with allothers. Others in then thread state it needs color bars.
Now, when I use a split gray scale pattern, the Y steps below 50% are at or around black and the others are at a overall reduce level, probably topping out at 50%. Only the analog sources are affected (analog TV channels and the composite input). Component, VGA, digital tuner channels and HDMI are fine.
When I re-tried the calibration, that magenta square does not move as it is suppose to do. Even after doing a factory reset, it just sits there. Lastly, even though only a 'AV' calibrate was originally attempted, HDMI & component also show failed. Of the four types of tests, only 'PC' shows success. No other input calibrate was done.
Why won't a factory reset allow the calibration to proceed?
post #158 of 170
Per others, a Color Bar test was done, but the same thing. That magenta square does not move. The process stops with a failure.
Since I wasn't there when the mistake was made, I never saw what the service menu stats were. For all I know those other inputs could of showed failed. He doesn't know either as he never looked. (He didn't know I had a signal generator and assumed what ever else was needed would be provide within the set. )
post #159 of 170
Originally Posted by foxlab View Post
Our TV was successfull.
If the calibration image on the TV MENU dark, blurry, or dark, is not worried.
Similar model to find the hidden menu settings you can write and impose themselves on TV.
hi,
I have the same model of ua40d5000 samsung LED TV.And my AV calibration is fail now .
How did you make it OK ?
Please help me and give me the steps.
Thank you .
post #160 of 170
Originally Posted by chan925 View Post
Just want to second this way of fixing it. I have a LN46B750 and I made the same blunder except it was my Component setting. I inverted the checkerboard like you did so the upper left square is black, then set my WDTV Live to 720p and displayed it there. It then succeeded in the service menu (and I got the hell out of there FAST after that ).
The checkerboard I used is attached for anyone else with a LN46B750. It might even work on the entire B750 line.
Thanks for chan925 in post 97 ! this worked great for Samsung UN46C5000 HDMI Calibration ! Since i did not have a USB drive I set the Blu ray player output to 720p, uploaded the image to Picasa Webalbums, opened the fullscreen image via VUDU Picasa app and it calibrated in 5 seconds ! v Happy
post #161 of 170
HELP HELP HELP.......
Hi to everyone
i m from greece and ny english is not so good.
i have this lcd tv:
samsung LE40A457C1D
and i make the same mistake with many others in here.
i push the right button on my remote while i was in service menu-->calibration-->HDMI calibration.
and now i m seeing .
i have an htpc connected on tv with hdmi cable.
what i must do to get sucess?
post #162 of 170
Hi to everyone
i have this lcd tv:
samsung LE40A457C1D
Run the calibration with the attached picture displayed in full screen. Calibration was a success after a few seconds for me.
post #163 of 170
Hi all, I apologize in advance for my English I have a computer UE40D5000 Samsung and I had the same problem with HDMI calibration error. I enclose your instructions, including the Annex calibration pattern. To do this, connect the PC to the TV via HDMI cable to HDMI / DVI input television. Set on a PC screen resolution to 1280x720 pixels. Display of the image viewer with me that the test pattern in full-screen mode (for example: Zoner Photo Studio) Run HDMI calibration service menu TV. In a few seconds the calibration is successful and you can sleep in peace as I did Before this calibration recommended FACTORY RESET in the service menu to adjust the colors back to factory settings!
And now for the Czech speaking both of which have something too
ZdravÃ*m vÂechny, předem se omlouvám za mojÃ* počÃ*tačovou angličtinu Mám Samsung UE40D5000 a měl jsem stejný problém s chybou HDMI kalibrace. Přikládám svůj návod včetně přÃ*lohy kalibračnÃ*ho obrazce. Postup je následujÃ*cÃ*, propoj PC s TV přes HDMI kabel do HDMI/DVI vstupu televize. Nastav na PC rozliÂenÃ* obrazovky na 1280x720 pixelů. Zobraz pomocÃ* obrázkového prohlÃ*Âeče mnou uvedený testovacÃ* obrazec v celoobrazovkovém reÂimu (napřÃ*klad: zoner photo studio) Spusť HDMI kalibraci v servisnÃ*m menu TV. Za pár sekund je kalibrace úspeÂná a můÂe v klidu spát jako já Před touto kalibracÃ* doporučuji provést FACTORY RESET v servisnÃ*m menu, aby se barvy upravily zpět na výrobnÃ* nastavenÃ*!
post #164 of 170
Put me down for messing things up too. This stems from a LN46A540P2 that I had replaced the main board and then upgraded the firmware to the latest from Samsung. The reason I was in the service menu in the first place was to try and correct what appears to a significant degrade in picture quality. The colors were OK but the compression artifacts and overall fuzziness were awful It was like looking through a screen window. Then I started messing in the service manual and accidentally ran the calibrate on HDMI. I finally got it back using the b&w grid patter. Thanks to all for the help. Now to see if I can restore the PQ.
post #165 of 170
I also made the mistake to run the "av calibration" test to get better PQ on my TV. after calibrating with chessboard pattern i was able to get 'success' (with too many effort) but the picture is still dark. also second option in ADC Result (1st_Y_GL) is disabled and cannot be changed. Is there any relation between other menus and options with this that might be changed?
Please help.
Edited by sxman - 11/10/12 at 2:59am
post #166 of 170
try this image. it worked for my tv. I had to make sure it was blownup fully on my tv.
http://img94.imageshack.us/img94/9644/checkerboardsamsung.jpg
post #167 of 170
hey,this is my first post here.
i screwed up my brand new samsung led tv UA40ES6200.
I calibrated av without knowing what it would do/require.
Although i was able to get "success" by using a checkernboard, the display is still very dark and the colours are way off mad.gif
i have done the calibration several times but the result is the same.
PS i used the same image to calibrate HDMI and the calibration was successful and the colours were normal. but with av i have no luck eek.gif
PPS the power led keeps on blinking when the TV is powered. it never did that before...
any help would be appreciated
regards
post #168 of 170
Hi,
I have a 32" Samsung B651 and I need to re-calibrate ADC values. There is something that I don't understand, because... when you enter Service Menu the tv goes into dynamic/standard mode, and I don't see the point in calibrating under those modes. The SM has this "WB Movie" mode wich you can enable and roll back to ADC calibration, should I do that?
Thanks for your answer.
post #169 of 170
SPANISH
Hola mi ingles no es muy bueno pero quiero compartir con ustedes lo del Lattice pattern chess.
yo tengo la tv modelo EH5300 Samsung Smart TV y me pasa lo mismo que a todos el maldito cuadro magenta no se movia por mas imagenes que le pusiera de fondo.
cada vez que hacia el AV CALIBRATION me pasaba lo mismo simplemente el cuadro magenta no se movia.
Mi televisor ya casi no se veia, las imagenes eran totalmente borrosas y aunque tal vez no quedo del todo bien.
Puedo decirles que la imagen mejoro muchisimo y estoy contento por eso asi que quiero compartir con ustedes lo que hice y como logre que la calibracion del AV finalmente dijera SUCCESS.
Entre en modo servicio de la Tv ya saben como es: Mute - 182 - power
-SVC
-Test Pattern
-Pattern Sel
alli con la flecha derecha del control escogemos el patron que estamos buscando ( el que parece ajedrez blanco y negro)
despues de esto le presionamos el boton del control remoto:
-Return
asi llegaremos al principio del menu de servicio y ahora nos dirigimos al menu para realizar la calibracion para esto elegimos lo siguiente que seguramente ya lo han hecho mil veces:
-ADC/WB
-ADC
-AV Calibrate
Una vez que hagamos esto nos dara SUCCESS
y la imagen mejorara.
IMPORTANTE:
Cuando estemos en el menu PATTERN SELECCION y hayamos elegido el patron de ajedrez una vez que salgamos del menu SVC, NO SE VERA EL PATRON. REPITO NO SERA VISIBLE EL PATRON. pero la prueba sera exitosa es como si el patron estuviera alli pero de forma subyacente.
Saludos y mucha suerte!!!
post #170 of 170
Hello
I have the same problem as most here: AV Calibration Failure, I've been trying a thousand ways I've found on the web and nothing has worked for me, my model is samsung tv HG32NA477PF, it sounds a little desperate but I've really been looking all everywhere and can not find a way ...
The test pattern is not functioning and no image of the chessboard ...
any other solution other than take it to repair?
Please help: '(
