AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Ps3 Firmware Upgrade
post #1 of 10
My player came with 1.0, 60gb version, cant connect to internet via wireless, please advise?
post #2 of 10
Try wired.
post #3 of 10
Stick it on a memory stick
post #4 of 10
Download it on a PC, and copy to usb stick, cd/dvd/bd following the instructions here:
http://www.us.playstation.com/ps3/ne...html#update_PC
post #5 of 10
I updated using my cameras compact flash card and it worked like a charm.
post #6 of 10
Who is your ISP? What router are you using? Because of the router my ISP provided, I had to switch the encryption method to connect.
post #7 of 10
Can I still find 1.3 upgrade some where? I have changed my ps3, back to 1.1, and if I can use CDR or DVDR to do so?
Please advise? it is for 20GB version so should I use USB storage or CD ROM
thnx
post #8 of 10
Please explain as I have tried other methods to no avail.
post #9 of 10
I finally found 1.32 as I had discarded one 60gb with 1.5. loaded on a usb storage precisely as folders desribed and it upgraded. Now I have 1.32, I did not wanted to connect to interneas it will make it 1.51. This is 20GB, now so did not take memory stick. now i have paied my remote control too
post #10 of 10
Another option is if you have a router in some other part of the house. Buy a long ethernet cable and snake it through the house to the PS3 temporarily just long enough to download the new firmware. Lowes sells 100' ethernet cables for $29.99 and 50' ethernet cables for $19.99.
Rick R
