AVS › AVS Forum › Audio › DIY Speakers and Subs › Box params
Box params
post #1 of 2
Help - I'm trying to do a rough simulation to pick a driver (thanks to all who suggested options in the earlier thread), and I'm having trouble fully understanding the Qb and Ql parameters. While I think I understand what they represent mechanically , I don't have a feel for an average or reasonable value. Given a sealed, cube-style subwoofer enclosure of 2-6 cu ft, what would the reasonable range of values be for these params?
TIA
post #2 of 2
Are you using Unibox? And referring to the modeling of box damping and leakage, by any chance? If so, use the scroll selectors to choose the type of damping you would choose to use and the degree of airtightness you would guess it will end up being. Other than that, I can't figure out what you are referring to.
