AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Directv/Tivo to Panny DVDR Problem
post #1 of 6
Hi all. My first post here, and I'm kind of embarrassed to admit I'm having a problem setting up my Panny DMR-ES25 to record saved programs off my Directv/Tivo box (HR10-250). I did a search, but could not find an answer.
Does anyone have this set up? I am unable to see the signal being sent to the Panny DVDR. I can see the on screen displays from the DVDR, so I know the hookup from it to the TV is OK.
I have connected the Tivo to the DVDR with an S-video cable into IN1 on the back of the DVDR, and set the input to IN1. I see no picture. I'm not sure if I'm doing something wrong, or if the Panny has a problem.
Any suggestions would be greatly appreciated.
post #2 of 6
You need the red and white audio cables for the audio. Just for grins you might try the yellow video conector just to see if it works.
post #3 of 6
Already tried the Yellow, and no luck. I've got the R&W audio hooked up. No sound either.
post #4 of 6
You need to set the HR10-250 to 480i mode to get a signal on the composite/s-video jacks.
post #5 of 6
I agree. Do you have the DVR set to 480i? If not that is your problem.
post #6 of 6
cnixon and Hoffa, that did it. Thanks a million!
  Back to Forum: DVD Recorders (Standard Def)
