I have a basement that is 23 x 17 x 9 and is already completely finished with paint, carpet, etc... I want to make this room into a theater with the main intent being to watch sporting events, play some video games and watch movies as well.
I have read a ton of posts here and looked at lots of pictures as well. I really want to go the projector route, but am concerned if it will be the best for my primary viewing. I plan on putting in a riser and some wall panels for sound, sconces, etc...
My first question is about layout. In the attached picture where should the screen go? There are advantages and disadvantages to each location. Putting it on the wall between the the stairway door and closet door makes it easier to run wires, locate equipment, etc... but, I'm not sure if the stairway door would pose any problems. There is no physical door going to the stairs. The closet door will remain closed obviously. The far opposite wall might be good too, but wiring will be difficult, plus I would have to fit the riser between the two doors mentioned on the opposite wall.
