Originally Posted by edorr
I am saying it does not lead to catastropic failure of the amp, because there is no record of a single power amp failing as a result of being used in conjunctions with a PS audio regenerator.
Maybe amps used with generators used in this mode have reduced MTBF, unbeknowst to their owners, which would lend some support to your argument. To prove this you would need a large sample of the same amps, run some with and some without the regenerator with the same load, and see if a statstically significant number of the ones connected to the regenerator fails first. Not an expirement I am looking forward to doing.
You're missing the point. Why not just run the amp on the power that it was designed to be fed with? Why force it to run on a power source that is out of standard specifications.
As I said before if the PPP outputs a clean 60hz sine wave than that's good, even better than running it on raw wall power. It's when we get into this "multiwave" crap where the risk problems is greatly heightened.
