Hello all, I have a question on setting up my Denon 3806's auto setup when using a sms-1 also. Should I unhook my main L and R channel speakers first then eq the sub with the sms-1 or leave them connected and eq with the sms? Also, after I run the auto setup is it ok to adjust the phase on the sms-1
? Im just really confused hear on the order to do all this because I dont want to screw up the results of the audyssey eq any. I have ran the auto setup a couple times already and got a couple different results as far as the crossover settings and the subwoofer distance audyssey set which in turn messes up the frequency response I had set before with the sms-1
... If anyone else has a sms-1 with audyssey that can help me out or anyone that knows the best way to do this im all ears
Brian
....Thanks,
Brian
