AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Any way to have a index of favorite subforums?
post #1 of 5
As a new user here, there are only about 2-3 forums that apply to me, and which I'm interested in at this time...so I was wondering...is there any way on this software to create a personalized list of sub-forums?
On the DSLReports forums, I can create a "My Forums" group that just lists those that I care about...sort of a quick index....yes, I could do so via making numerous entries in my IE Fav's but would prefer something on forum...
This is more of a problem with forums like this that have SO specialized areas...as some sub-forums will never apply to me, due to budget and my interests/usage.
post #2 of 5
If you subscribed to a FORUM and then go into the USER CP area, those forums are then listed. You then can use the URL for the USER CP when you enter the site to see the list...
Here is the link to use for the USER CP http://www.avsforum.com/avs-vb/usercp.php?
Hope this helps.
post #3 of 5
Maybe I'm just having an early senior moment, but I only see the ability to subcribe to a THREAD (which I've done for those that I've posted to) but not to subscribe to those Forums... BTW, other forums I'm on have this same software base, and same issue applies to them...I think DSLreports has some customized s/w for that function..
post #4 of 5
When you are in a forum section...at the top right of the thread list you will find FORUM TOOLS. Click on that like you do when you are in a thread.
post #5 of 5
Ok...now I get it! I'd hadn't seen that before...sorry....
and then had thought it'd show up when viewing http://www.avsforum.com/avs-vb/subscription.php? as separate group at left, but see it's handled differently...
Well, now that I know, it's kinda obvious...DUH! Thanks for the QUICK help!
  Back to Forum: Forum Operations Center
