Hey folks,
Getting down to the end stages of my basement HT build and I'm installing a drop ceiling in a 12' X 26' room. After reveiwing some past threads I've read that buzzing and rattling may be a problem. My questions are:
Is the problem with the tiles rattling on the frame or the frame itself?
Can this issue be prevented by selecting a heavier acoustic tile? Will the mass be enough to prevent this issue?
Is it necessary to tie or bind all the hardware to create a solid frame?
Does adding a layer of insulation above the tiles solve this problem?
Looking forward to your suggestions.
Ryan
Ryan
