AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Please help make my mind up for me for I am confused
post #1 of 7
I was dead set on upgrading my Optoma H31 to the Optoma HD70 in two weeks, but recently I have been reading a lot about the Mitsubishi HD1000u and it sounds really good as well. Prices are about the same, but I noticed that the Optoma HD70 does 1080p through downscaling and the Mitsubishi HD1000u isn't listed as doing such.
Any opinions either way would be great. I really appreciate the help. Thanks.
post #2 of 7
1080i/p wont really matter as you are only projecting in 720p.
post #3 of 7
The HD1000U is the superior projector overall regardless. Glass lens, 10-bit instead of 8-bit, doesn't have the color accuracy issues, is brighter and higher contrast when calibrated. The HD1000U can be had for $899 or less too.
post #4 of 7
Where do you recommend getting it from? That is a fantastic price.
post #5 of 7
Call projectorpeople.com and tell them you heard about them and the projector on avs forum.
post #6 of 7
What Gwlaw99 said.
post #7 of 7
I would strongly advise you to read Art's reviews of both units at projectorreviews.com before you make a decision. I have looked extensively at both units and my own opinion is that it is not as cut and dried as some might have you believe.
OTOH--you truly can't go wrong with either of these units.
