AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › How to "Feather" One Color to Another
post #1 of 2
I have a media room with a theater setup on one side. The room color is carried throughout except for the screen wall which is black.
I now would like to paint the ceiling and soffits between the PJ and screen wall black also.
How do you feather or transition from the black to the room color ?
I work well with pictures
post #2 of 2
I take it that you want some sort of fade effect rather than a sharp line. You can do this with a fairly dry roller pulling from the wet color into the dry color. It won't be a perfectly even blend however. It can be done with a brush. Experiment a bit.
Good luck
