Hello all, I posted a question the other day in audio setup forum but had not gotten a response so I figured it may be better to post it here anyway. I have a SMS-1 and a Denon 3806 and was wondering on the order I should setup things
...I can eq the sms-1 then run the audyssey which I have done but audyssey seems to change either the sub distance the crossovers or both and in turn messes up the frequency response unless I go back and change the phase on the sms-1. Can I change the phase on the sms-1 after I run audyssey auto setup
??? Also when eq'ing the sub on the sms-1 should I unhook the main speakers or no
Thanks for the help,
Brian
??Thanks for the help,
Brian
