AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PS3 is only using front speakers and subwoofer
post #1 of 3
I have my PS3 connected to a Pioneer VSX-84TSXSi with composite cables (HDMI cables come in on thursday), and the receiver is connected to a front projector with an HDMI cable. I have a 7.1 surround sound home theater, but with the PS3 only the front speakers and subwoofer are playing.
I tried it with CDs, regular movies, games, and even a blu-ray movie and it still doesn't work. The only setting I saw in audio setup was something to change the connection cables.
Just to make sure it was the PS3 and not the receiver, I plugged in my laptop to the receiver and it worked just fine.
I have a friend over who is leaving on wednesday, and I'd really like to get the surround sound to work before then. What else can I do?
post #2 of 3
Are you using the Optical connection for audio ? Be sure to go into the Audio Settings on the PS3 and check the Optical settings for DD and DTS .
If you are using the analog left and right audio cables then you cannot get surround unless you use PLIIx on the receiver (and this will only be a simulated surround) .
---- Jason
post #3 of 3
I am using the composite cables that came with the ps3. I changed the setting to games on the receiver and it works now.
  Back to Forum: PlayStation Area
