What is the range of voltage levels and SNR levels that are needed for typical interruption-free HDTV experience? For old analog UHF signals, I seem to recall (20 years ago) that these numbers were around 44 dB SNR and around 1mv (0dBmV) or better for a grade A picture, and about 10dB lower for a grade B picture. As has been noted by many others, digital reception is more of a matter of cliff signal, where it is either coming in or it isn't (no shades of gray or snow).
I assume that the SNR of the of the signal at the transmitter does not matter, and that all of the different kinds of noise seen at the receive antenna (4:1 balun) can be simplified to something like 75ohms at some temperature (sky or ambient?) over a 6 MHz band, resulting in an approximate noise floor number (-53 dBmV or so + 1 dB for the balun)? If this is the case, what is the needed minimum voltage at the balun output to reliably receive an HDTV channel, if the ATSC receiver (often called an ATSC tuner or HDTV tuner) were right at the balun?
Is this oversimplified, in that other forms of distortion (IMD, etc) or other items are likely large contributors? If this is about right, we should be able to determine when it makes sense to buy a bigger antenna or buy a pre-amp, or go home
