AVS › AVS Forum › Display Devices › Rear Projection Units › First impressions of the new JVC thin (Slim D-ILA) RP sets
post #1 of 449
Everywhere else that I've seen web reports on the new "Slim D-ILA" sets from JVC, they were just rehashes of the JVC press release. Peter Putnam at HDTV experts actually saw the new sets, and shares his observations, albeit brief. Takeaways from the mini-review are:
  • The display uniformity looks pretty good; I was nervous about this. His specific comments: "The 10.7 depth was achieved by using a concave mirror in the projection engine. Its not a new idea, but concave mirrors bring their own problems to the table, such as brightness falloff and uneven focus both of which could hamper sales of an RPTV. The sample I saw had neither problem the test HD images were acceptably crisp and detailed in the corners of the image, and image brightness appeared to be within one f-stop (50%) from the center to the corners."
  • The lamp is UHP and its power is 120 watts, which seems a bit lower than I expected. This might require a higher gain screen. He didn't comment on viewing angle, particularly vertically.
  • The bezel around the display is a VERY narrow 0.4". This sounds very cool from a visual perspective. It will also make the width of these sets about as small as is physically possible.
  • JVC has used an aluminum frame in the new sets to provide the highest strength and rigidity while keeping the weight low. Putnam comments that this might dent, and is concerned about it "over temperature extremes". Aluminum has a lower thermal expansion coefficient and a much higher softening point than plastic, and I have to believe that JVC designed within the elastic limit. Sounds good to me.
  • He states that the thin sets "use the latest 0.7" D-ILA panels". They clearly don't have the wire grid polarizers found in the just released DLA-HD1 front projector with 15,000:1 native contrast. But there could be some evolutionary tweaks between the thin set LCoS panels and the 2006 models. Jury's out on this one.
  • He comments on a "new, 5th generation Genessa image processor", but this is the same language as is used for the 2006 models.
  • He also comments on a "10,000:1 contrast ratio by using a new optical iris system". The 2006 models also used an optical iris, but I haven't seen any contrast ratio claims for these. It is conceivable that the 10,000:1 represents an improvement.
Here is a link to the mini-review:
http://www.hdtvexpert.com/pages_b/jvc_dila_rptv.html
Here is a link to the JVC announcement:
http://jvc.com/press/index.jsp?urlid...m=530&pageID=1
The attached file has details on the design of the new thin sets. By slashing RP set depth essentially in half, I think that this is a major advance in RP technology, and will make these sets more competitive against LCD and plasma. I will carefully check out the new 58" as soon as I can find one (they are due to ship "in January"), but will probably hold out for the 65" in March.
Slim D-ILA.pdf 387.6318359375k . file
post #2 of 449
I'm anxious to see how these sets perform.
The 58" and 65" aren't much thicker than plasma -- thinner than plasmas with their factory stands -- and cost about half as much for a 1080p display of that technology in similar size.
post #3 of 449
I never thought I would see it happen but these new JVC's with the new
D-ILA panels have the potential to be the best RPTVs of 2007. If they are using
the latest panels, they should be the same as the new FPs. No mention of a
dynamic iris to achieve 10,000:1 CR so this is likely. I am curious
if Sony is going counter with RPTVs with new and improved SXRD panels sooner
rather than later?
Can't wait to check them out at CES...
Is the 120 watt bulb only for the 58 in.?
post #4 of 449
I agree with you that these may prove to be the best RP sets of the first half of 2007, but the iris is, alas, dynamic; that's how they get the 10,000:1. JVC is launching their latest advances for their FP unit, and will trickle it down to the RP models at a time of their choosing. We may see some non-polarizer advances in the Slim D-ILA sets, but it's a crap shoot at this point. Your point on the bulb is a good one; I would hope that the 65" has a higher power bulb.
post #5 of 449
They must not be using the same panels as the new FP? Or the optics to
facilitate a really thin RP must be degrading PQ quite a bit...
I would certainly take the specs of the new FP before a super thin model RP any
day of the week... Who knows, maybe we will see a fat a$$ 80+ in. with the new
panels soon.. That's what I want to see :-)
post #6 of 449
There are several major factors in the contrast of an LCOS system. One is the panels and the other is the optical path. LCOS panels these days are typically 5,000:1 (ignoring for the moment JVC's claim of their new 15,000:1 process). JVC's RPTVs use a "Color Quad" based on Colorselect(tm) filters by Colorlink. This optical system has inherently less contrast than systems involving separate polarizers such as the particularly high contrast wiregrid.
I'm pretty sure Sony uses wire grid polarizers in their SXRD RPTVs, so I can't see why there is a reason not to use wire grids in RPTVs. In any event, the cost of wire grid polarizers has come down a lot and would not seem to be the limiting cost factor. My guess is that JVC has stayed with the color quad based design because it is a little less expensive and because they had the design in the pipeline but there may be other reasons.
post #7 of 449
I'm eagerly waiting for more reviews on these slim sets. Even though they don't have the latest 15,000:1 CR D-ILA devices used in JVC's new FP, if the PQ of these slim sets matches JVCs current generation 1080p RP sets, I'll be buying one for sure.
Anyone know if the electronics have been enhanced at all? I'm hoping they upgraded the PC connector to accept a full 1920x1080p signal (I believe current JVC 1080p sets only accept 1024x768 over the PC connector, which is basically useless IMO).
post #8 of 449
Second you on the computer input question. I have no idea why they crippled this on 2006 models. Of course, any subsequent desktops or laptops I buy are likely to have an HDMI connector, but it would still make sense to up the PC connector resolution a lot.
post #9 of 449
JVC is showing these new slim D-ILA RPTVs at their private booth in Las Vegas.
Please post your impressions if you have the opportunity to view / demo these displays.
post #10 of 449
From JVC HIGHLIGHTS NEW TECHNOLOGIES - January 7:
LED HD-ILA
Replacing the current high-pressure mercury lamp in JVC's rear projection HD-ILA televisions with LEDs would provide quick start and extremely long product life. The wide color range allows for flexible color management. Combined with the latest wire grid-based optical engine and latest D-ILA devices, it achieves a startlingly high contrast ratio.
Did anyone see this demo? If so, when does JVC expect to ship displays with this technology?
From JVC HIGHLIGHTS NEW TECHNOLOGIES - January 5
Thin HD-ILA Projection Television
JVC's HD-ILA line of rear projection HDTVs has been well-received in the market thanks to its use of the company's D-ILA microchips, a form of LCOS (liquid crystal on silicon) technology developed by JVC that is renowned for its close pixel spacing, which delivers a bright, detailed and smooth true color image. In development is a new optical projection system that makes use of a new configuration to allow a cabinet depth of just 10 inches, a 40 percent reduction in depth compared to current models, yet cabinet height remains the same, as does brightness. JVC is demonstrating this technology with a 56-inch prototype.
LED Backlight HD-ILA & LCD
JVC is exploring the use of LEDs as the light source for both HD-ILA rear projection televisions and flat panel LCD sets. In HD-ILA applications, the LED would replace the current high-pressure mercury lamp. Benefits include faster response for a better image during fast motion scenes, stable operation, and extremely long product life.
post #11 of 449
In the posting that started this thread, I thought the bulb on the new sets seemed a bit underpowered. I remembered wrong. All three of the current JVC sets (56", 61", and 70") use a 110 watt bulb, and have a total power of 215 watts. The new 58" and 65" Slim HD-ILA sets have a 120 watt bulb, so lamp power has actually gone up. I looked around at plasma sets for comparison; most brochures conspicuously don't mention the power, but checking the Panasonic 65" owners manual it comes in at a smoking 795 watts! Great for summertime viewing! That difference of 570 watts, assuming 5 hours of viewing a day in a household (1825 hours a year), and 10 cents per kilowatt hour, comes to $104 per year. If the current bulb technology lasts 5000 hours, then the savings in electricity over that period is $285, essentially neutralizing the cost of replacing the bulb.
post #12 of 449
That was announced months ago. Question is; are they only "exploring" or will we see them this year??
No, great for wintertime. No need for a furnace.
Makes Plasma look good (if that is possible).
post #13 of 449
... I looked around at plasma sets for comparison; most brochures conspicuously don't mention the power, but checking the Panasonic 65" owners manual it comes in at a smoking 795 watts!
There's an informative article on CNET on that. As I recall, the problem with measuring the power consumption of plasma sets is that unlike competing technologies the power consumed varies with the brightness of the image. 795 watts is the maximum, presumably with an all-white image. Darker scenes use a lot less. They provided measurements to give you an idea of the consumption pattern in normal viewing.
post #14 of 449
Some more product information from Gizmodo:
http://gizmodo.com/gadgets/ces2007/j...row-227597.php
Notes of interest:
  • HD-ILA 3D Television: "this TV was really just a modified version of what they had on the market now"
  • Cinemawide Television: "it was not built in the 16x9 (1:78:1) format, but the 1:85:1 film standard"
  • LED HD-ILA: "This was by far the showstopper."
post #15 of 449
If you visit JVC's off-site booth, please ask about support for 24p, and whether they have improved the video processing in these new models.
JVC's 2006 models had trouble at times detecting the 3/2 cadence for film sources (CBS, NBC, HBO, etc) broadcast at 1080i.
post #16 of 449
All you need is a $150 nVidia Video card (nVidia has better drivers then ATI, simple to create custom resolutions to deal with overscan issues).....which will also bump up your PC's performance. (cause any decent card made in the last few years has at least DVI out)
Many laptops too....my Dell I9300 17" lappy (almost 2 yrs old) has DVI out (6800go 256mb video card), I'll be grabbing a DVI-HDMI from monoprice real soon to hook it up for some great gaming!
These new thin sets look very interesting, nice to see JVC step on it a bit, innovation is what the company built it's foundation on.......
post #17 of 449
Any info on when these sets are supposed to be available? Would like to compare it at my local B&M store against the current 06 models.
post #18 of 449
The 58" is supposed to be available by the end of January.
post #19 of 449
Thanks for the suggestion, but on examining the manual for the current 56, 61, and 70" sets, I noticed this in the specifications:
HDMI Jack x 2
The HDMI terminal is not compatible with picture signals of a personal computer.
A link to the current sets manuals is here:
http://books.jvcservice.com/download...9322/40437.pdf
Assuming that the HDMI - PC incompatibility is true, and the PC connector is limited to 1024 x 768, PC connections look a little bleak. In fairness, I haven't trolled the current sets users thread, and the new Slim HD-ILA models may have improvements.
post #20 of 449
http://gizmodo.com/gadgets/ces2007/...rrow-227597.php
Notes of interest:
* HD-ILA 3D Television: "this TV was really just a modified version of what they had on the market now"
* Cinemawide Television: "it was not built in the 16x9 (1:78:1) format, but the 1:85:1 film standard"
* LED HD-ILA: "This was by far the showstopper."
Melakai: Thanks, great find! The link has some amazing news! LED LCoS RP with 1,000,000:1 contrast ratio?! That's more than SEDS ever claimed. 3D LCoS?! Bring it on! Dedicated 1.85:1 wide displays?! JVC is really pushing the innovation button. Given the miniature size of the displays, we might even see a 2.35:1 version, for both FP and RP (the incremental costs to do this are a LOT lower than for full-sized flat panel sets). I have been holding off jumping into HD for too long already, and so will probably buy the bulb based, 65" Slim HD-DLA when it goes on sale in March, even though hotter stuff is apparently in the wings. At this rate of progress, though, I may keep it a lot less time than my current seven year old old 56" Toshiba SD CRT rear projection TV.
I have taken the liberty of pasting the full text from your link below:
I visited JVC's technical demo room corner, where I couldn't bring a camera, but I thought you might suffer through my bad humor/grammar for a little vicarious "future of JVC" action.
Microprojector
They had a microprojector about the size of a biggish pocket, with smooth detailing and one button. I couldn't see any inputs and this was not running.
Mini-DV to MPEG2 Converters
Directly beside the projector were two similarly rounded boxes, the first of which was about the size of the projector. I read the sign to see what this was. Mini-DV converter. The technical rep anticipated my surprise, explaining that Mini-DV is a technology that will soon be phased out, but many consumers would still have a large library of home movies they didn't want to lose. This box converts them to MPEG2, which can be burned to a DVD. A model about triple its size was close by, which had a built in DVD burner.
You need to wear shutter glasses to see the otherwise blurry image in 3D. I put them on and watched a jeep driving through some sort of wooded area. While certain parts of the image felt very pop-up book, with multiple 2D layers, the road and its patches of grass were quite immersive. The image fluttered to black at a constant, and once again anticipating my question, the rep explained that this demo could only run at (30HZ?) per eye, but he was confident that they could reach the necessary 60 for a seamless image. Then he added that this TV was really just a modified version of what they had on the market now, streaming a 3D-encoded DVD.
Cinemawide Television...err...HD-ILA Technology?
I should have taken better notes. I couldn't figure out what drew me so much to this large, 60" or so TV. Then I was told, it was not built in the 16x9 (1:78:1) format, but the 1:85:1 film standard. It just felt more like a movie. {Edit: 1.85 is only 2% per side wider than 16:9. If it felt that different, might his lack of notes suggest that what he actually saw WAS 2.35:1??? Did anyone else see this demo???] Edit 2: I was right. It has been confirmed as 2.35:1!
LED HD-ILA
This was by far the showstopper. It was displaying The Corpse Bride with blacks that looked like Black. I asked the tech rep about the contrast ratio. He smiled, "It's 1,000,000:1."
The picture was beautiful. I wish I could have seen a clip with more color and wider tonal range to really test what it really could do. - Mark Wilson
post #21 of 449
Melakai: Thanks, great find! The link has some amazing news! LED LCoS RP with 1,000,000:1 contrast ratio?! That's more than SEDS ever claimed. 3D LCoS?! Bring it on! Dedicated 1.85:1 wide displays?! JVC is really pushing the innovation button. Given the miniature size of the displays, we might even see a 2.35:1 version, for both FP and RP (the incremental costs to do this are a LOT lower than for full-sized flat panel sets). I have been waiting for the next and better for too long, so will probably buy the bulb based, 65" Slim HD-DLA when it goes on sale in March, even though hotter stuff is apparently in the wings. At this rate of progress, though, I may keep it a lot less time than my current seven year old old 56" Toshiba SD CRT rear projection TV.
Microprojector
LED HD-ILA
How do LEDs give it such good blacks when they gave DLPs worse black levels?
post #22 of 449
Your question is a good one. Ignoring the possible duty cycle penalty of wobulation, DLP and LCoS should benefit equally from LED illumination. If full 1080P DLP devices are in fact here, even that issue may soon be history. JVC may be the first to exploit a novel LED modulation or drive method, who knows? If the quote by a JVC rep by "Mark Wilson" of Gizmodo is correct, perhaps both LCoS and DLP will show large contrast improvements soon.
post #23 of 449
It's the implementation.
I've read reports of a LED DLP prototype in the TI booth that has similar raves about it's blacks.
post #24 of 449
Ballz2TheWallz; You don't have to 'quote' the entire long post especially if it was right above your reply. Makes the thread longer than it meeds to be...............
post #25 of 449
Notes of interest:
That statement is wrong. Cinemawide is 2:35:1. You can see it in the background on this picture. Looks awesome!
post #26 of 449
They can control the LED light output based on the overall brightness of the scene somewhat like many of the current sets use a dynamic iris. If the scene is black, then they turn the LEDs off and thus the somewhat extravegant claim.
DLP sets have made similar claims on contrast ratio using the same technique. The thing I have noticed is that DLP sets using LEDs seem noisy and my speculation is that they have traded mirror flips for color depth to reduce the rainbow effect with LEDs.
post #27 of 449
Originally Posted by JETninja View Post
All you need is a $150 nVidia Video card (nVidia has better drivers then ATI.... blah blah blah
You're missing one very big market segment. Xbox 360 owners would LOVE a full bore VGA port. Come on, JVC!!!
post #28 of 449
HDMI Jack x 2
Don't waste your time trolling... my 2005 HD-61Z786 states this in the user manual:
HDMI jack x 1
Note: The Digital-In terminal is not compatible with picture signals of a personal computer
...but I've been using it with an HTPC for almost 2 years now. 6600GT video card with DVI out into the HDMI port via a DVI -> HDMI cable. I can't imagine the current models are any different.
post #29 of 449
Anyone seen these in action?
post #30 of 449
HDMI jack x 1
As are many people in the FN/FA/FC 56/61/70 Owners thread. (I own the FN61) HDMI from a PC with either HDMI or DVI works great and accepts 1080P from your PC. There is around a 5% overscan, so using the nVidia drivers or Powerstrip, you create a slightly smaller image....and your off watching movies, surfing, playing games. It works very well.
And Microsoft will not miss the very obvious HDMI market for long....the PS3 has not made a big enough dent yet, but it will and MS will respond I'm sure....that said the XBOX360 can output through Component. I doubt you'd miss much letting the JVC do the up-coversion from 1080i to 1080p.
  Back to Forum: Rear Projection Units
