If anyone is using a linksys router and has a low signal % and would like to raise it, I have found a product that works. I bought this high gain antenna system for the linksys WRT54GS I have and it raised my signal levels from the 70-80% I was getting before (would sometimes dip into the 60's) to a constant 95-97% now. I highly recommend it to anyone who is having low signal levels and would like a boost. All you do is unscrew the old ones and screw these in! takes less than 1 minute!
http://www.amazon.com/o/ASIN/B0002F3...722216-3210041
Other companies also make high gain antennas but i can only vouch for the Linksys ones in this post.
No one cares about my stupid little network enough to manage to break my regular WEP encryption, and thats all you need to keep other average users from getting on.
