AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › XA2 Review
XA2 Review - Page 2
post #31 of 369
Keep in mind that the original poster also changed out his projector and it was the synergies of both components with ISF calibration that he's commenting on.
post #32 of 369
I think the poster's exuberance is more related to the ISF calibration's impact rather than a more superlative player. I believe the poster is simply outputting 1080i. I wouldn't expect an astounding difference as it seems the A2 he compared it to was not optimized.
post #33 of 369
thebland,
I totally agree with you.
So, ugh, which of us is going to buy one first?
post #34 of 369
I want to see the issues related to the A2 resolved.. (e.g. audio & HDCP).
post #35 of 369
If this is true, can someone do a direct comparison of the A1/XA1/A2 to the XA2 outputing 1080i? I'ld like to see this.
J
post #36 of 369
Big J
You're not asking much, are you?
post #37 of 369
Originally Posted by Hoof View Post
Can someone explain what exactly makes the AX2 have a superior PQ over the A2? I was under the impression that 1080i60 and 1080p60 would look the same on a 1080p tv.
I would speculate deep color and the Realta chip.
k
post #38 of 369
I expect this unit to be as good as or better than the Pioneer blu ray unit (which has amazing picQ). Adding a XA2 should give me the best of both worlds...
post #39 of 369
k
would that chip make a difference only for 1080p or 1080i as well?
post #40 of 369
This is driving me nuts.
I'm at work and my XA2 is sitting right next to me and I have three more
hours before the fun begins.
post #41 of 369
Originally Posted by JimP View Post
Big J
Sorry, I'm considering upgrading my A1, but my SXRD only accepts 1080i. I know the A1/Xa1/A2 look pretty much the same, but if this is a significant improvement even at 1080i, I'll consider it. If its just a moderate improvement, I'll wait. I'ld also like to know how the upscaling is compared to the other players.
J
post #42 of 369
Cough Cough...Boss I don't feel good.
post #43 of 369
k
The discs don't have deep color on them.
J
post #44 of 369
J
My point is that its extremely unlikely a user (to differentiate from a seller) is likely to have all 4 models. Objectively, I'd rather hear what user collectively have to say after a couple of weeks when the warts appear.
post #45 of 369
Big J
He really isn't.
His post:
J
He asks for "a direct comparison of the A1/XA1/A2 to the XA2 outputing 1080i".
That's a A1 or A2 or XA1 vs. XA2.
Not, as your implying; a A1 and a A2 and a XA1 vs. XA2.
See the difference?
Maybe you thought it was A1 & A2 & XA1 vs. XA2?
I'm hoping this thread becomes a sticky w/the title "XA2 Reviews".
That way, every single time some lucky person gets one, they wouldn't start a "new" thread!
Agree!
And crush issues as well.
post #46 of 369
There already are a sticky. Not that it's being used correctly either.
http://www.avsforum.com/avs-vb/showthread.php?t=768634
post #47 of 369
Big Ed is correct. Since the A1, XA1, and A2 have basically the same PQ, a comparison of any of them to the XA2 would work.
Yes, this thread should be a sticky.
J
post #48 of 369
I find this hard to believe that is is 'a lot better than the HD-A2'? Was your A2 ISF calibrated as well? In what respect is it 'a lot better'?
If it is free of the plaguing issues on the HD-A2, I may get one myself!
It's not hard to believe the xa-2 has hdmi 1.3 for deep color and the reon chip for sharpness and a more 3d look.
post #49 of 369
To the best of my knowledge, HD DVDs do not have deep color. It isn't even in the specs.
J
post #50 of 369
J
Also, previous versions of HDMI already support "deep color" using YPbPr component.
Steve
post #51 of 369
HDMI audio works perfectly with my equipment and the A2. Perhaps it is your audio processor.
post #52 of 369
Originally Posted by Chris in SD View Post
HDMI audio works perfectly with my equipment and the A2. Perhaps it is your audio processoR
Nope....It's the HDA2 that's the problem. However, my HDA1 was OK on HDMI audio as is my Panny Blu Ray player, JVC 5U D-Theater deck, Pioneer 59AVi. All provide audio via HDMI through my Halcro processor.
post #53 of 369
Not really. They support 10bit or 12bit YCbCr, but only in 4:2:2. If you want 4:4:4, YCbCr is limited to 8bit with HDMI 1.2, just like RGB is.
post #54 of 369
Just because some other units work ok with your processor doesn't automatically mean that the A2 is the source of trouble.
A2s are working with all sorts of other equipment. Have you reported this problem you have experienced directly to Toshiba or is your agenda merely to consider slighting Toshiba HD gear in this forum?
post #55 of 369
Then what was the point of adding it if HD optical discs aren't going to use it? Broadcast will never use it.
post #56 of 369
I will keep saying it HDMI sucks!
post #57 of 369
It will carry Lossless audio, but mostly its a sales gimmick.
J
post #58 of 369
Playstation 3 > Toshiba XA2
post #59 of 369
Based on what?
The PS3 can't even upscale SD-DVDs.
The PS3 doesn't have the class leading de-interlacer and image processor found in the XA2.
The PS3 doesn't have analog outputs for direct output of next generation audio formats like True-HD to seperate audio processors and amplifiers.
About the only thing the PS3 has going for it is that you can play some crummy first generation games that don't hold a candle to the current Xbox 360 offerings.
post #60 of 369
I cannot imagine that the PQ of the XA2 is much better than the A2, why should it? Okay, the XA2 has the Reon, but when you say that the XA2 is a class better, than tell us why.
  Back to Forum: HD DVD Players
This thread is locked
