I just picked up the PS3 this week from BB when they got their latest shipment in(60GB model) and also picked up a few BD discs as well. While I'm not one to really buy a component that doubles as something else, the low price point was really hard to resist for a BD player. I own the Toshiba A1 and have had it since the summer, and while I thoroughly enjoy the picture and sound, having it limited to 1080i and the slooooooooooooow boot really gets to me sometimes. Instead of selling it and trying a newer HD DVD player, I figured I'd give BD a try.
Picture wise in case anyone cares, I can't tell the difference between BD & HDDVD, and my eyes are pretty well trained. Even with one outputing 1080i and one outputting 1080p(I'm projecting it using the Sony Pearl). Neither could I tell if one sounded better than the other, although the A1 was a LOT easier to setup. I have no idea about the different sound options on the PS3, lots of decimal numbers and Hz, but I have no idea what my receiver can handle or what the PS3 should be set to(Pioneer Elite 84TXSi in case some one knows and wants to share which I should have selected?).
Anyway, back on topic, my PS3 makes my speakers hum or hiss noticably, especially during quiet scenes. I have worked painstakenly to avoid any hum/hiss in my setup, so this probably bothers more than it might most. But it is noticable even to my half deaf friend. I'm using an HDMI cable connected to my receiver, I've tried 2 different cables and both exhibit the same noise. Has anyone found a solution to this, or has it just become something people live with? I really like some of the movies that are only on BD, so I would like to stick with it, but I can't forsee me keeping this unit. I think the next thing I have my eye on is the Pioneer BD player, but I can't seem to find much info on it, other than it doesn't use a Bluetooth remote!
(WTF Sony???).
Anyway, I just wanted to relay my experience in case others have found any sort of solutions to this.
Chip-
(WTF Sony???).Anyway, I just wanted to relay my experience in case others have found any sort of solutions to this.
Chip-
, maybe it's the spot in my rack. I'll try the optical and a different location tomorrow and see if that helps. Although my main priority right now is being able to ungrey out the greyed out 1080p selection.
