AVS › AVS Forum › HDTV › HDTV Technical › How to receive broadcast Hd channels without a built in tuner
post #1 of 3
I have an older hdtv that does not have a built in tuner. I do not want cable or dish I just want to receive hd channels with my antenna. What type of equipment do I need and where would I find it. Thank You.
post #2 of 3
See http://www.avsforum.com/avs-vb/showthread.php?t=179095 which is a sticky thread at the top of this forum. Start with the section "Over the air DTV/HDTV".
The new Samsung DTB-H260F has been getting mostly favorable reviews, and Circuit City carries it, if you can find a store that has stock on hand. There's a long thread about it in this forum which you should be able to find easily.
post #3 of 3
I'll check it out. thanks
  Back to Forum: HDTV Technical
